TLR 22T Thread
#4261
8th scale blockades, I beams and rest is mixed.
i just found these http://www.hpiracing.com/piw4.php?part=4411 but how are there compound compared to others.
in the morning track is wet and fluffy. Towards the end it grooves up and everything hooks up for the most part.
current layout
http://www.youtube.com/watch?v=pdRlx...8mo20m&index=1
#4262
Komodo's are a square pin tire.
Komodo, or a bowtie or goosebump in the morning fluff and then I would switch to a Panther Raptor or PL holeshot, JC DD type tire as the track grooves up as it still looks pretty bumpy out there. Not sure a bar type tire would be the ticket.
4x4 sc most people run blockades, enduros
current layout
current layout
#4263
Anybody got a good setup for a loose outdoor with large jumps? Preferably using only the kit parts.
#4264
#4267
Ok cool that's what I've got on it now with the raised tranny. Gonna try 2 hole pistons today to see if that helps with landing the big doubles. Also has anyone used shock limiters to prevent bottoming out? I've noticed that when the shocks are fully compressed the wheels go up passed the chassis.
#4268
#4269
start with
Box stock setup
Emulsion shocks 25 all around
rear camber link 1b
white springs rear
4*toe
shortest wheel base
rear arms shimed foward 2mm
56 grams added right in back of battery
(battery I run is 6600 mah)
no limiters in rear shocks
raised tranny 1mm
#4270
What should I try if when i turn, the rear inside wheel picks up and I spin out? It happens at all speeds, even when I go slow. It happens under braking and no braking. I am running the kit setup on carpet.
Any ideas? You think I have to much bite in the front? Longer camber link?
#4271
Are you running limiters in the rear shocks?
#4274
