TLR 22T Thread
#5913
Make sure your servo is spaced so that it not only clears the top deck thing, but that the steering linkage clears the horn. Mine has clearance issues until I used to spacers to space my servo forward. Ended up using 2 mm spacers with Spektrum servos. I am using the following spindles and caster blocks: TLR1103 Spindles 22T inline, TLR1060 0 Degree caster blocks 22 Buggy. Everything is perfect here.
#5914
#5915
TLRacing
Everything clears, nothing hitting, just doesn't seem to get to full throw. Using Savox 1257 without spacers as any spacers would make the servo horn hit the bell crank. Also put on the SCT 2.0 turnbuckle links as indicated to be required. I've spent had to long screwing around with this, guess its back to the slider.
#5917
+1
+1
#5919
Ok, I'm getting closer to full throw. I have a Savox 1257 with the TLR22 alum. horn. Found that I had to add a 2mm spacer under servo horn ball so that the servo link would not touch the horn when going full in one direction. EPA at max radio of 150 each side.
Things are so tight tolerances that I could see how people might have issues using different servos/horns/etc/
#5921
anybody use the rt6 MM on this 22t to see if it fits?
http://www.amain.com/jconcepts-kyosh...-clear/p297149
#5922
tired of waiting frank going to by associated for this season stadium truck
#5923
I get it.......but seriously just do what I did. Pick up a reasonable priced used 22T and put the 2.0 shock parts on it and a bellcrank steering setup. I even put the 2.0 battery mounts in mine and mounted the ESC on the chassis, think it will work well. Probably basically what the 2.0 will be IF a new one comes at some point.
#5924
#5925
Grades along with the brass rear anti-squat blockfor mm, the truck is the best of all of them I have driven.
