Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 06-16-2008, 11:19 PM
  #9346
majicman's Avatar
Thumbs up
94,
Thanks for the info. Hard to naviagte the sea of parts on the Tamiya site.
majicman is offline
Old 06-17-2008, 06:42 AM
  #9347
tc3team's Avatar
Originally Posted by majicman
What is the best shim to use as a wheel spacer between the hex and wheel to widen the stance of the car? I know that some use 1mm shims but what is the OD/ID or part number people are useing?
Probably hard to source now, but I found some white 2mm hex shaped shims off an old HPI Pro2 parts tree fit nicely. Just remember that they may stay inside the hex of the wheel when you think you have lost them...
Or just some m3 sized standard washers should be good enough for a 1mm shim.
tc3team is offline
Old 06-17-2008, 05:31 PM
  #9348
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Core Creations
In the Standard 05 suspension there are only 1 and 2 degree rear hubs. But you can cancel the toe with the toe blocks.
As far as I know there are no different length arms for the standard suspenion. You can use the short arms designed for the TA04SS...but they are short as in wheelbase not car width.
There are varying lengths of arms for the lightweight suspension. I'm not sure exactly the difference but it's between 1-2mm per arm.
And yes, the hard rear hub on the standard suspenion is 1 degree.
I have always been under the impression that the non- 2 degree rear uprights were 0 degrees not 1, but I can always be wrong
I am running from front to back 1D ,D bridge, 1B, 1D
With the hard 2 Degree uprights.
This setup makes the car very wide, so you need to run the 5mm hexes
BP SHADOW is offline
Old 06-18-2008, 09:47 PM
  #9349
waOscar's Avatar
Originally Posted by 94eg!
Tamiya sells them in two different colors (red & blue). I don't know if they are the same thickness or not (I would bet they are the same). 53646 & 53647
Differant colour, differant thickness.1mm red0.5mm blue(unless its the other way around)check it athttp://www.tamiyausa.com/product/rcpss.php
waOscar is offline
Old 06-19-2008, 07:37 AM
  #9350
94eg!'s Avatar
Trader Rating: 17 (100%+)
I believe you that they are different, but Tamiya never makes mention of it. Kinda weird. I have the blue ones that came with my MRE, so I am inclined to believe they are the .5mm ones...
http://www.tamiyausa.com/product/ite...oduct-id=53646
http://www.tamiyausa.com/product/ite...oduct-id=53647
94eg! is offline
Old 06-19-2008, 08:42 AM
  #9351
Hi,
No, just different colours, both packs contains two sets (4 each) of 1mm and .5mm. Red seems harder to find tho.
AllShowNoGo is offline
Old 06-19-2008, 10:54 AM
  #9352
JCarr's Avatar
Does anybody make ceramic diff balls that fit the TA05? I've been trying to find them and come up empty handed.
JCarr is offline
Old 06-19-2008, 11:42 AM
  #9353
Core Creations's Avatar
Trader Rating: 108 (100%+)
No, the stocks are 2 and the hards are 1.
http://www.speedtechrc.com/store/ebp...id=461&id=1710
Core Creations is offline
Old 06-19-2008, 01:07 PM
  #9354
ah_DaN's Avatar
Does anyone know which roar legal lipo other than the orion fits in the stock tub chassis without modification?
ah_DaN is offline
Old 06-19-2008, 01:58 PM
  #9355
majicman's Avatar
Default TAO5 ready lipo's
If you are looking for LIPO batteries that fit ito the grooves of the chassis like a 6 cell pack, the Oroin 3200 fits in the stock battery slot.
I beleive the Orion 3600 may as well as both have the same general form factor as well as the feet on the bottom that allow it to fit into the battery slots.
majicman is offline
Old 06-19-2008, 02:05 PM
  #9356
I have 3200 3600 4800 and 5000 from Orion, Checkpoint, Core...etc, everyone of them fit the TA05 tub chassis. No mod....
Solara is offline
Old 06-19-2008, 03:56 PM
  #9357
myan_gsr's Avatar
Try Rcmarket
http://rcmarket.com.hk/product_info....roducts_id=660
myan_gsr is offline
Old 06-19-2008, 04:03 PM
  #9358
ah_DaN's Avatar
I got the Orion 3200. Want a bigger one.
Does the Reedy 5000 fits?
Their price is pretty good. Under $100
ah_DaN is offline
Old 06-19-2008, 04:05 PM
  #9359
94eg!'s Avatar
Acer racing sells 3mm ceramic diff balls for $13 in packs of 10...
http://www.acerracing.com/products/3...ls-773-66.html
94eg! is offline
Old 06-19-2008, 05:13 PM
  #9360
DRKSYDE's Avatar
on my 05r i put 3mm shims on the axle with 5mm clamping hubs and still cant get 28mm foams to clear the ballcup on the steering knuckle. the tires are the old style rims(parma)not the newer larger style rims. any sugestions besides some creative grinding?
DRKSYDE is offline
