Team Associated TC6.2 Touring Car
#1726
It is a bit different from the kit but just more tuning options to choose from. The front arms and caster blocks are from the TC5. The rear arms are TC4 and the hub carriers are modified from the BD7. The servo mount and parts are all from the kit but I cut them down with a dremel. For my carpet rebuild I will be putting a brace across the top of my steering posts.
To be honest I haven't had a whole lot of track time on the 6.2 and this started out as just a duplicate of Steve Weiss' Reedy Race setup. His car looked amazing there so when I came over to AE I knew that's where I wanted to start.
I also thought about getting a second servo mount brace to cut into two then having all options from one-piece, two piece or without a brace on the steering posts at all.
Is it possible to modify TC6.2 rear hub carriers instead of using BD7-parts?
#1727
And why would you use older arms and hub from tc5 apart from terrible slop you get from 6.1 hubs
#1728
The reason for using the tc5/tc4 arm combo is that it gets the pin length ( in and out) the same front and rear. The car rolls more consistent in the corners and the feel of the drive is better. Yes you can use the 6.2 rear hub modifying the bottom to work on the tc4 arm. Just requires some dremel work.
#1729
front: TC6.2 0.5mm shorter than TC5 and 2.5mm shorter than rear TC6.2
rear: TC6.2 2mm longer than TC5
So TC5 arms front and rear seam to be equal lenght to me.
But what is the lenght of the TC4 arms measured from center of one pin to the other (or with the pins installed from outside to outside of the pin)?
#1730
machine screws are in inches?
#1731
millimeters
#1732
I just used the front arm in the rear and removed a little material to make the rear hubs fit.
Without wanting to show off, I have to say my car is awesome right now. I could dominate the modified class in todays race even though I had no tracktime but ten minutes and drove this track the first time in two years.
This setup just works great on carpet. The only thing I adjust is the balance. The track today had much more steering than my hometrack, so I gave more rear toe in.
#1733
What did you use, to mount the rear roll bar mount?
Thanks!
#1734
Thanks a lot! I appreciate you answering all the questions put to you!
That being said I have also seen plenty of 6.2's with kit geometry work extremely well, so both ways can definitely work just fine for those that don't want to switch out to the older parts.
Get a second CF servo mount piece and cut it up, I can get you a closer pic of how I cut mine if you'd like. Just another tuning option!
#1735
Ey Randy, iīd like to know, why you are using tc4 rear ams, and tc5 front arms?, why donīt use tc4 rear and front arms, or tc5 rear and front arms?, besides that the roll bar mounts are quite different between rear and front.
Thanks!
Thanks!
As for the swaybars, they are off the BD7. You'll need the plastic clamps from the TC5 to make them work.
#1736
So is ae working on any of this to release an update for us?
#1737
I'll be completely honest with you, I basically worked right past the parts that the setup didn't use so I don't know the exact differences with geometry. I lucked out a bit with my timing and was able to build my car with a setup that has already been proven to work well and I just copied it exactly.
Pic of how you cut the servo mount piece would be nice. Might help ...
