Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 04-08-2009, 02:54 PM
  #5056
94eg!'s Avatar
Trader Rating: 17 (100%+)
Originally Posted by or8ital
Actually isn't it anti-squat since it is on the rear? Though I guess "front rear" has two meanings. Is it the front piece of the rear of the car of the rear piece on the front of the car?
You are correct. Anti-squat refers to the rear suspension. Anti-dive refers to the front suspension. Therefore from his mention of anti-dive, we can deduce that he's refering to the rear block at the front of the car...
94eg! is offline
Old 04-08-2009, 03:16 PM
  #5057
Adam?'s Avatar
Originally Posted by TryHard
That adds anti-dive, and also reduces castor. The reduced castor is the bit that helps entering the turns... as the Anti-dive helps to resist weight transfer forward, as the arms take some of the suspension loading as the picture below shows...
HiH
Ed
I've been thinking about this some, and I guess what I'm feeling is the increase mid-corner and exit. Entering the turns seems pretty similar. I need to analyze it again when I'm at the track. It really woke the car up, and allowed it to carve up the corners better.
Adam? is offline
Old 04-08-2009, 04:29 PM
  #5058
bigkoitat's Avatar
Trader Rating: 6 (88%+)
I've been running "kick-up" in the rear with some very good handling on some medium grip asphalt. Compress the rear on corner exit on throttle and transfers weight to the front off power corner entry.
bigkoitat is offline
Old 04-08-2009, 04:42 PM
  #5059
CraigM's Avatar
Trader Rating: 34 (100%+)
The first time I tried anti-dive I didn't like it because it took away on-power steering. I figure this was because it works both ways so as well as being anti dive it is also pro-lift. I tried it again over the weekend but with minimal front droop and that sorted it right out, and it really made the car an weapon under brakes - I always found the 416 a bit floaty in big braking zones with a tendency to back its way into corners but now I can jump on the picks and it's stable as with heaps of turn-in
CraigM is offline
Old 04-08-2009, 07:03 PM
  #5060
Trader Rating: 68 (100%+)
After searching thru the for sale forum i can find a 416 for sale. Anyone looking to get rid of one. I looking for a roller with some parts. Thanks for any help you can give.
todb is offline
Old 04-10-2009, 07:30 AM
  #5061
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Anti-Squat
Randy Caster is offline
Old 04-10-2009, 11:24 AM
  #5062
bigkoitat's Avatar
Originally Posted by Randy Caster
Anti-Squat
That's what I meant, I'm dyslexic
Old 04-10-2009, 11:35 AM
  #5063
Happens all the time to me, lol.
Old 04-10-2009, 01:55 PM
  #5064
Just don't get your Gigididdy mixxed up with your Shishmoigan.
John St.Amant is offline
Old 04-10-2009, 01:59 PM
  #5065
Umm.. Kick up is anti-squat for the front end.
I do not recomend running the front of the front arm lower than the rear of the front (negative kick-up). For instance most Buggies have between 15 and 30 degrees of kick-up built into the chassis. What the first illustration here shows would be pro-dive if it were in the rear. I don't recomend that either. +$0.02
Old 04-10-2009, 02:04 PM
  #5066
bigkoitat's Avatar
it's contagious How you been? I need to get up to Bending Corners one of these days. I've been running the Orion motors in my cars and WOW! What a difference!! The motor's I was running were about a year old, but properly maintained. But the Orion's just friggin rock, I've been running the 10.5 for mod but want to move up to 8.5-5.5.
Old 04-10-2009, 02:23 PM
  #5067
Low_E's Avatar
I posted this question also elsewhere but might try to find info overhere as well.
During the summer I will go on a holliday to the south of France. There is a track in the neighbourhood (tarmac) and the local drivers run nitro and electro.
They do however, run with foam tires. As I was thinking of training there, should I try to run foamtires on my 416 as well? Were I run, we only use rubber tires. I understood foam-tires have much better grip.
If so, what tires should I look for and are there typical setup changes I should use?
Low_E is offline
Old 04-10-2009, 03:03 PM
  #5068
Actually I run anti-dive on a lot of my setups, it really helps get the car into the corners harder, but makes the car harder to drive and more twitchy feeling. Once you get it set up right it can cut down the laptimes a little bit on decent grip med to tight asphalt tracks.
Old 04-10-2009, 03:06 PM
  #5069
I've run at DHW once, used a 3.5 with 5 cells, and because the track was run clockwise the back straight was slightly down-hill, man my car was fast that day, lol.
I've been doing most of my practice at the Tamiya USA facility, which they are thinking about resurfacing soon, so the track will be like new after that. We also have WCRCR opening up in La Mirada in the next couple months, he's going to lay fresh asphalt inside the huge warehouse, and will have on-road and off-road tracks, both at about 100-110ft x 50-60ft, should be awesome.
Old 04-10-2009, 03:44 PM
  #5070
bigkoitat's Avatar
I ran a 3.5 before on my older car at DHW but only had a one-way at the time so it was alot harder without brakes and proper set-up. I'm going to give it a try next race now that I have brakes and proper set-up. That La Mirada track sounds awsome!! Do they still have practice at Tamiya on Saturdays?
