Kyosho Ultima RB6 & RB6.6 Car Thread
#4968
i thought i would try the saddles, but i already know i will probably go to a shorty.
next paycheck tho
Edit: what shorty packs are you guys running? i would like to get one at a decent price, dont want to spend 100$ if i dont have to, if its a good deal i wil get 2 . thanks
next paycheck tho
#4969
OK - now I get it.
#4970
I've read the first post but i'm still confused about the rear suspension hangers. I'm running rear motor and broke the stock RF hanger and replaced it with the mid motor RF2. Was the original one a RF or RF2 ? The back hanger(RR) doesnt have any markings on it. So by my thinking if the back is a (RR) and im running a RR2 in front I have little or no rear toe in HELP !!!!
#4972
Technically it raises and lowers your front roll center, at the lower control arm position. No spacer for less roll/steering, larger spacer for more roll/steering. See if you can even tell a difference.
On another note I ran the Cody turner setup from petit and it was very good. Better then the Japan setup imo.
#4973
For the rear rear hanger use the wide one from the tree with the RF2.
#4974
So are the castor blocks are part (111)UM715? I think the manual calls them a hub bush hence my confusion.
#4975
The setup sheet calls the rf2 the wide hangers. Is that a mistake? There are a number of spelling errors on the sheet.
#4978
