RC10B4.1 FT/WC
Old 12-05-2011 | 01:45 PM
  #8161
carbons2k's Avatar
Originally Posted by Asharus
tom you noob, we don't use diff fluid in our BALL DIFFS. check the electric off road section, there's a guide posted up by racer53 stickied up top that should help you out a lot. racing tomorrow?
oh ha! ok ill check it. yes ill be there with the buggy
carbons2k is offline
Old 12-05-2011 | 02:31 PM
  #8162
AzRon's Avatar
Has anyone tried the hints that are in the thread "Tuning with camber links" ?
I have read thru it and down loaded and cut and pasted hints from it and now it makes more sense on how to set up my car, wouldn't it make more sense to use this as a guide for your track instead of copying someone elses that may or may not work?
I ask this as i read thru many pages of setup questions that may be answered by this thread and wonder if it works or not. Thanks Ron
AzRon is offline
Old 12-05-2011 | 02:33 PM
  #8163
Originally Posted by -WHEELMAN-
No spacing needed! I ran on a large medium bite track red front springs 30 weight oil #2 piston and yellow spring 27.5 weight oil #3 piston in the rear and it was great! The silver front springs and pink rear may suit a higher bite track? They didn't work at all for me! Chassis pushed with no rear traction. For you on a medium bite track to keep in mind.
what collars are you guys using?
Colts is offline
Old 12-05-2011 | 02:39 PM
  #8164
tommy911t's Avatar
Checked amain this morning and noticed they are out of the rpm losi spring mounts. that may have caught them a little off guard, although they are probably on rctech.
Thanks agin for all the set up sharing. my b4(one of the few still running at my track) is running awesome!
Is the two hole castor block luck of the draw or are there sources/part numbers?
tommy911t is offline
Old 12-05-2011 | 03:15 PM
  #8165
bds81175's Avatar
Moderator
I've tried it both ways (tuning cars, that is ). I'm not a great tuner to begin with and my driving makes it even tougher to tune properly. If you are scrambling to play catch up to the other racers and have two younger kids' cars to work on in addition to your own, its real easy to slip back into copying setups. My setups from Tuning with Camber Links have definitely been different than typical setups. They tend to have stiffer springs out back in most cases with a rear motored car. There's more than one way to skin a cat! At a bare minimum you are smarter and less ignorant about how to tune your car.
bds81175 is offline
Old 12-05-2011 | 03:20 PM
  #8166
-WHEELMAN-'s Avatar
RPM 70322
-WHEELMAN- is offline
Old 12-05-2011 | 03:37 PM
  #8167
YankeeFan123's Avatar
Just use the clear diff lube that comes with the kit
YankeeFan123 is offline
Old 12-05-2011 | 04:18 PM
  #8168
916bdogg's Avatar
Talking
How Bout that Red And Yellow B4.1+8mm Whooping those TLR Boys This weekend Back In Mil,Wisconsin!
916bdogg is offline
Old 12-05-2011 | 04:19 PM
  #8169
916bdogg's Avatar
Talking
Associated is Madfast !
916bdogg is offline
Old 12-05-2011 | 05:11 PM
  #8170
Jason Haas's Avatar
Please share , I want to see that set-up ....
Front end
1/A camber link with 2 washers
0* of toe
30* caster
Inline steering blocks shim the caster block back and move the stud back on the steering rack.
Steering block in the middle of the caster block
2 washers for bump steer
1/outside for the shocks 2 limiters 30wt #2 piston orange Kyosho spring
ride Height 24mm
-1* of camber
Rear end
1/b camerlink with one washer on a shaved u brace and c taps on the hubs.
0* hubs with c taps middle wheelbase (blue washer in the front)
3* of toe in the rear and 2* of antisquat
Inside/inside on the shocks 27.5 wt #2 piston 2 limiters Dark yellow kyosho rear springs.
ride height 24mm
-1* of camber
1/2oz behind toe block
1/4 oz in each rear triangles
1/4 oz in each front triangles
Jason Haas is offline
Old 12-05-2011 | 08:06 PM
  #8171
dumb question, but what is the U brace mod. I'm trying to search for details but no luck... anyone got a link describing it or something I can catch the eff up.
Bob Barry is offline
Old 12-05-2011 | 08:23 PM
  #8172
Guest
u brace mod???? are they cutting off the numb where the tire rod end screws in to??
LOSIRACER77 is offline
Old 12-05-2011 | 08:45 PM
  #8173
no clue, that's why I asked. Something to do with the C hub tower or something I think. But like I said, I'm playing catch up.
Old 12-05-2011 | 08:59 PM
  #8174
Guest
i dont know either????
Old 12-05-2011 | 09:00 PM
  #8175
brent701's Avatar
If I am understanding how he is wording it
He is cutting the upper two parts of this brace #9564 where the Ball cup studs go in, to lower the camber link
Upper corners if that brace in the pic
Not cutting but shaving down flat to match the rest of the brace. Lowers the link about 2.1mm
I did this on my SC10 and it is working well. It really works well if you have FT rear blue hubs and the Carbon fiber hub towers. which lower it 2mm at the hubs
brent701 is offline
