RC10B4.1 FT/WC
#661
Your just the kinda guy I was hoping to hear from, I'm gonna order a T4.1, I was tempted to try something different but you just can't go wrong with AE. I've been running a FT B4 and I just love that car, do you know if the new B4.1 rear shock tower will bolt onto the old b4? Is it worth switching over to the new hubs and cva's? Thanks again for all your help!!!!
Almost all of the chassis components such as the chassis, the A-arms, and shock towers are manufactured from new molds. These new molds leave almost zero flashing. No more breaking out the xacto blade when installing a new front arm. Did you ever notice that when you crank down on the front hinge pin brace that it binds up the travel of the front A-arms? The new kit doesn't do that. The bottom of the chassis is completely smooth, no more "circle thing". The front of the chassis has been beefed up just a tad and they added a set screw for the antenna (not a big deal, but a nice touch). The rear shock tower has the new 4th hole position and provides more clearance for taller batteries. It uses B44 spring cups in all 4 corners to allow for better clearance from the A-arms. The bottom plate is different and allows for the revised gear box. There are other differences too, but these are some of the main ones that I noticed that actually improve the car.
All of these changes make the car more tunable, easier to maintain, more durable, and easier to work on.
#662
I think the plastic is a little different too. At least it looks and feels that way.
#663
My FT T4.1 kit I just assembled Tuesday did not have the 4-hole rear shock tower. I had to drill it. Anybody definitely get one with a 4th hole? Just curious. Other than that, it went together great and drove even better at our wednesday club race, using the only T4.1 setup on AE's site.
#665
#666
I drilled a 4th hole in my old t4 tower though for a setup. Is the t4 shock tower the same in the 4.1? Or is it modified to have the "4th" hole position as well? Please confirm.
#667
The new B4.1 tower does not need an additional hole and yes it will bolt right into the B4.
#668
There is NO new hole on the truck rear tower. Its just the sc10 tower, new material and it allows for larger lipos.
Only on the buggy.
Only on the buggy.
#669
The T4.1 shock tower is the same geometry. In our testing, we did not find that the shock tower needed a revision like the B4.
The B4.1 tower has 3 holes only, but all holes are shifted inward compared to the B4 tower. All spare parts will be updated as a running change. Carbon towers unfortunately are not available in the updated version.
Kurt
Kurt
#670
Sorry, I should have clarified that the B4.1 shock tower does not actually have 4 holes. I and others call it the "4th" hole because on the old shock tower you had to drill a 4th hole yourself. Now they have added the "4th" hole and eliminated the outer hole. Sorry for the confusion.
#671
an update for this transmision binding.. make sure the bearing for the slipper shaft is pressed into the deep hole. mine did the same that everyone speaks of until i pushed my nut driver in there and heard it snap into place. now i can tighten the case down and it spins free. if you notice in the pic i quoted that area is next to the slipper shaft.
#672
Super Moderator
Trader Rating: 31 (100%+)
I thought I had mine right but I'm gonna pull it apart and hope this fixes the problem, FT SC10 (built 2) is butter smooth but my B4.1 had this issue..PISS ME OFF!!!.....and noisy!! holy crap sounds like Slash for god sakes..
#673
In case your vehicle is loud i'd suggest you take a look at the spur.
Some aren't very round at all, i replaced my kit spur to a RW spur and it's much quiter.
the kit spur just didn't spin true.
#674
Super Moderator
Yah, I hear ya, FT SC10 is dead quite with the kit spur and cheap RR pinion, FT B4.1 has kit spur and same cheap RR pinion so I'm hoping it's loud from the tranny issue but I doubt it....I hate load cars!! R/C not the real thing, I have old fogy neighbors that flick me off when I drive by with my truck..
#675
I'm considering a new truck but am torn between the T4.1 FT and the new Kyosho RT5. I've always loved AE for their simplicity and parts availability, but I have heard really good things about the RT5, Anyone have experience with both who can tell me some pros and cons from the 2? you guys are always helpful Thanks....
I prefer the T4 it suited more for my driving style better then the RT5..
RT5 never seemed plated to the ground.
very twitchy.
not enough rear traction.
quick change wheels are around.
best shocks on the market.
good steering.
T4 A-arms can be fragile at times.
turnbuckles another weak spot.
leaky shocks.
plenty of steering.
jumps great.
planted to the ground.
tons of parts support.
