Like Tree5Likes
SC10 4x4 Thread
Old 12-02-2011 | 06:59 AM
  #11746
symmetricon's Avatar
It is clear that we were/are not all physics majors. Thank you Krio for tht moment of clarity. You are spot on, while the physics are the same comparing different scale shocks, the assumptions, due to different mechanics, in the algorithms used to determine the shocks charectaristics are different. Meaning they do not translate 1:1.
I hope we are done with the bickering. We are just going to confused people more than they already are.
Back on the topic, the sc10 4x4!!!
Question, has anyone broken an idler gear who did not have the topshaft pinned????
symmetricon is offline
Old 12-02-2011 | 07:09 AM
  #11747
I did! Have yet to do the pin mod since I'm running on medium to high traction tracks lately and I have worn out one rear idler gear since I bought the truck when it came out.
Krio is offline
Old 12-02-2011 | 07:32 AM
  #11748
fastrc64's Avatar
Default krio
are you going to the northern nationals at PRG next weekend ? if so i'll see you there
fastrc64 is offline
Old 12-02-2011 | 07:34 AM
  #11749
oh wow imma get this soon.
rsmugs is offline
Old 12-02-2011 | 07:39 AM
  #11750
I really, really, really want to, but it's up in the air at the moment... I blew ~$300 to replace the 22" hdtv in my living room with a 40" led hdtv on black Friday.
On the up-side I don't have to sit 12" from the screen to play black-ops and I did save a bunch of money on my car insurance.
Krio is offline
Old 12-02-2011 | 07:50 AM
  #11751
CraigMBA's Avatar
Was not just some guy , and I can't use his name due to fact you would still call it a lie, ect ....
Please believe me it was not false or a lie as you claim I am doing .....
again
stop trying to get on my goat ...
You are entitled to your own opinion, but you are not entitled to your own facts.
I am not trying to get your goat, get on your goat, get at your goat or otherwise touch your goat. However, I am pointing out what you wrote was malarkey. And I will continue to do it until you either let it drop, or show proof of your statement.
Your choice on how we go from here.
Originally Posted by Krio
In short, we can't just copy full scale shocks and expect them to work the same. However, we can use things learned ON full scale shocks and appropriately modify a smaller shock to behave like the full scale shock, but it will be nowhere near a true "scaled down" model.
IMO this is correct. However, this is absolutely not what the other user was advocating. It may even have been what the other user ment, but it's not what the other user wrote.
CraigMBA is offline
Old 12-02-2011 | 07:59 AM
  #11752
fastrc64's Avatar
lol dude funny . hope you can make it . Ryan cavalieri, dakotah phend as well as others will be in attendance as you know . can't wait to see what the new track layout will be
fastrc64 is offline
Old 12-02-2011 | 08:03 AM
  #11753
Wild Cherry's Avatar
Craig
My Advise
Just Calm Down ....
Wild Cherry is offline
Old 12-02-2011 | 08:05 AM
  #11754
CraigMBA's Avatar
Originally Posted by bradp29
to anyone who can make sense of this. If ther is slack in the belt will it cause a delay in the front wheels pulling faster than the rear?
No, but the lash from the belt might cause some wierd issues in the slipper biasing, which will really show up if you have a rough track that is also dry slick where you might have the slipper a little looser than on a smooth, high bite track.
To me, this sort of situation (the one you are describing) is where the pin modification really shines.
CraigMBA is offline
Old 12-02-2011 | 08:06 AM
  #11755
Whole new track after they just changed it for the states? Wow... I was hoping it would stay the same since I can't make it out friday night for any type of practice and I would at least be somewhat prepared in the first qualifier.
Krio is offline
Old 12-02-2011 | 08:10 AM
  #11756
fastrc64's Avatar
yeah new track layout i will be there friday they race sunday and after the race they will change it . the track is 3.5 hours from me so it is a drive but well worth it
fastrc64 is offline
Old 12-02-2011 | 08:19 AM
  #11757
CraigMBA's Avatar
As a patent pending product based on this notion, I'd like to bring back the AE volume compensator foam blocks used on the original tc3 shocks. With that below the piston and a bladder above you get the consistency of a bladder shock and closer than ever handling characteristics of an emulsion shock.
I missed this one.
The problem with the foam bladder is it isn't static and it degrades rapidly as it absorbs oil. The shock shaft displaces the oil in the cylinder and compresses the foam by forcing oil into it, but it doesn't remove oil at the same rate on the rebound side. After a while, these diaphragms take on the consistency of rocks. On a sedan it was okay because the shocks had very limited travel, but on an off road car, not so much.
If you had trackside access to a shock dyno, you could "see" when the foam started to break down and change the shock accordingly.
The OG Losi JRX-2 shocks had a foam bladder inside the shock cartridge. The biggest development Losi did in the early cars (the ones before the XX product introduction, like the LXT) was get away from that and move to an emulsion style shock. They did not leak every other race day, and the car did not bottom out on large jumps with 80 weight oil any more.
CraigMBA is offline
Old 12-02-2011 | 08:28 AM
  #11758
Originally Posted by CraigMBA
I missed this one.
The OG Losi JRX-2 shocks had a foam bladder in the shock cap. The biggest development Losi did in the early cars (the ones before the XX product introduction) was get away from that and move to an emulsion style shock. They did not leak every other race day, and the car did not bottom out on large jumps with 80 weight oil any more.
Craig, the AE volume compensating foams were strictly an example of the concept of having a compressible medium on both sides of the piston, not to argue their supremacy by any means.
Krio is offline
Old 12-02-2011 | 08:37 AM
  #11759
CraigMBA's Avatar
Understood. I was just pointing out the practical problems with those units.
My carpet oval car has VCS side shocks, and they require service every other race day because the foams get compressed down to about 1/4 of their original size and the car won't handle the same as on fresh inserts.
CraigMBA is offline
Old 12-02-2011 | 08:40 AM
  #11760
CraigMBA's Avatar
Originally Posted by lodhammerdin
Wild cherry, if you haven't noticed, this guy thinks he's "house" and thinks he knows everything and can fix anything. All he does is troll and bash people from what I can tell. He's probably gonna bash me for this post but I don't care. I just wish this thread could get back to what its supposed to be about... helping people with there sc10 4x4's
My flame suit is on craig, it's only a matter of time!
Just letting you know, I take avatar requests!
CraigMBA is offline
