Team Associated RC8Be Thread
#7203
What you want is: 1) 8.2 wing mount 89540 2) 8.2 front arms 89550 3) 8.2 rear arms 89551 4) 8.2 F sway bar kit 89530 5) 8.2 R sway bar kit 89531 6) R upgraded shock tower 89484 7) F upgraded shock tower 89483
This will change few components of suspension geometry making car much more stable. New 8.2 wing mount takes care of having to modify old wing mount.
#7204
I have an extra RC8Be sitting around collecting dust that I'd like to convert to SC10 to beat up some Slash 4x4's. I heard this can be done and not too costly. Has anyone done this and can tell me exactly what I need for it to be legal. Will it run on 2S with right set up? Thanks for any help!
#7205
http://http://www.rctech.net/forum/electric-off-road/352424-my-4x4-sc10.html
I did one, not running it on2S though. I will try with my Mugen conversion though, it's lighter
#7206
quick questions, since I am converting from a nitro for the winter can I use the stock 44T metal center diff gear instead of the plastic 46 that comes with the conversion kit? Are they all mod 1? I know the electric stuff is, but the pinion to spur meshed seemed a little on the rough side compaired to the 46 plastic. I am running a sensorless 1750kv motor and the 2 tooth difference will help with the gearing especially if I am going to run the 18-20 tooth range pinions for indoor.
also, I havn't picked out my batteries yet, can a 40C 5000 4s turnigy soft pack fit in the battery tray without modifications?
#7207
#7208
#7209
If you want to use the 8.2 towers I believe you need the 8.2 shock shafts. It has been reported that the geometry doesn't change between the worlds and the 8.2 towers only the height. It was said that the towers were change so that the regular shock ends could be used.
#7213
The way I understand it is; The 8.2 has shorter shock towers. Therefore needing shorter shock shafts. To bring it all together the springs have been revised also. If you use "upgraded" shock towers, the old (if you will) shock sets will be correct mounted to the 8.2 arms. I don't know if one setup has an advantage over the other, but I don't believe so. Someone correct me if I'm off base...
#7214
#7215
Just got a Rc8be just looking for tips on setup. I drove it today and it sounds like back end or something is scraping on take offs or landings. Also if anyone know if they make or where to get alum castor blocks.
