Tamiya TB-Evolution IV >
Like Tree2Likes
Old 07-20-2004 | 01:14 AM
  #676
JDM_DOHC_SiR's Avatar
Originally posted by ngo8
so does the suspension kit come with the rollbars and what size is the chassis 3mm or 2.5mm ?
Rollbars 1.4mm in the kit and the chassis is more like 2.6mm
-Dave
JDM_DOHC_SiR is offline
Old 07-20-2004 | 01:18 AM
  #677
Originally posted by HYPA
Hey guys, just ordered my Evo IV today and I was wondering if Tamiya have released a titanium turnbuckle set for the car? If not will any of the 415 turnbuckles fit?
Cheers
Tamiya will have a ti turn buckle set for the EVO4 ..but it`s not out as of yet.....but I have used the TRF alloy ones and I ordered 4 32mm ones 2 28mm ones and 1 spsre on for the steering servo from the 415 (38-40mm).
-Dave
Old 07-20-2004 | 01:48 AM
  #678
FW-05RR's Avatar
I hope they come out with the Evo IV Surikarn Edition with red anodized parts
FW-05RR is offline
Old 07-20-2004 | 03:28 AM
  #679
Originally posted by V12
Thanks Dave.
so if I want using the suspension upgrade kit on the EVO III maybe I also should go for the 415 blocks.
Is the EVO IV using AA blocks or DD blocks in the front?
Things like wheelbase and battery position may be a little different but in the end this should be very similar to an EVOIV.
just finished putting ti screws and turnbuckles on.
i think this is the lightest car ive ever had.
the suspension blocks are same height as evo3 blocks.
on the front the car comes with AA blocks for front and AE blocks on rear.
you could put 415 blocks on to lower that roll center but remember to readjust the droop.
the car comes with silver anti roll bars and links and mounts.
iam just using the bars from the 415/evo3 range.
trf racer is offline
Old 07-20-2004 | 04:38 AM
  #680
Originally posted by izzyracer
This might be to much to ask. but for ones who already has the EVO 4, can someone put together all the screws necessary to make up the kit?
I'd like to have my screws ready.
Izzy...
Here you go
3x14 Button x4
3x12 Button x8
3x10 Button x12
3x8 Button x36
3x16 Counter x2
3x10 Counter x5
3x8 Counter x35
I hope this helps you all out to get a head start
-Dave
Old 07-20-2004 | 05:47 AM
  #681
Originally posted by JDM_DOHC_SiR
EVO4 Blocks = 415 Blocks
No they arnt, they are evo 3 ones ie 415 ones + 1mm. Rick
Rick Draper is offline
Old 07-20-2004 | 05:57 AM
  #682
OK if you want to get "Super Tech" on me they are .789mm taller.. ... But I have switched out the rear A & E blocks for the 415 ones also the rear front A block for the 415 A block for a smigine more kick up ..
But thanks for the correction to what..I forgot to update..
-Dave
Old 07-20-2004 | 06:02 AM
  #683
HPZ
Hey guys, since the evoIV doesn't come with the roll bars is it possible to use the evo3 ones instead?
HPZ is offline
Old 07-20-2004 | 06:03 AM
  #684
hawker's Avatar
i believe so, i'll being doing some testing with that later on tomorrow
hawker is offline
Old 07-20-2004 | 06:04 AM
  #685
HPZ
oh ok thanks... just seeing what i can still keep in my old evo3 hehe
HPZ is offline
Old 07-20-2004 | 06:05 AM
  #686
opps double post
  #687
The EVO 4 does come with 2 roll bars..1.4mm front and rear...but they are silver
-Dave
Old 07-20-2004 | 06:06 AM
  #688
jeffreylin's Avatar
It does. Just one set though (silver).
jeffreylin is offline
Old 07-20-2004 | 06:08 AM
  #689
HPZ
Is the silver roll bar any particular stiffnest? eg. soft , medium or hard? i'm quite noob when it comes to these things, i like to get my info right
HPZ is offline
Old 07-20-2004 | 06:09 AM
  #690
similar to the Yellow ..or Med ones from Tamiya
-Dave
