Arrow Racing GTR .21 Engine Thread >
Old 10-05-2011 | 01:18 PM
  #316
Maximo's Avatar
Originally Posted by dreaux
It is without a doubt cast. It's ugly under there, but there is a good bit less matierial. Pretty sure it's lighter.
Never had a cast piston before
Cast is heavier then machined normally
Maximo is offline
Old 10-05-2011 | 01:25 PM
  #317
houston's Avatar
Tech Prophet
i just rebuilt a vspec for a local , he provided parts which i am pretty sure were arrow parts and all fit perfect , ran great
parts quality/finish nowhere near that of the japanese made vspec parts but crank seemed to be much harder steel (bonus) , needless to say the engine ran great
the piston looked "speckled" as you said marcus , maybe neal knows for sure but i am pretty sure the partsare a direct fit to the original OS engines bore x stroke combo
btw , the rod didnt look near as finished and in past experiences rods with sharp edged machining did not last
hope this helps
if your curious novarossi machined piston is quite a bit heavier than cast
houston is offline
Old 10-05-2011 | 01:46 PM
  #318
hope this helps
I have a new speed rod, would that be better?
dreaux is offline
Old 10-05-2011 | 01:49 PM
  #319
Did they make up tech lord just for you
dreaux is offline
Old 10-07-2011 | 11:59 AM
  #320
VPProUSA's Avatar
Xray's Patrick Castleberry is now using the Arrow GTR-21 engine.
VPProUSA is offline
Old 10-07-2011 | 01:27 PM
  #321
From needing some extra heat on the Arrow GTR .21 motor to first crank it over, I thought of making these.
Custom Machined from Steel 2.5 inch OD and bored to size for ID with about .015 clearance, also is milled out for exhuast port and around carb body, to concentrate heat to where its needed down thru the piston casing
http://www.youtube.com/watch?v=HnM_eHtNCxs
I have a few already to size for the Arrow GTR .21
$21.50 includes shipping, http://pages.suddenlink.net/hotheadsrc/
Ramirez24 is offline
Old 10-15-2011 | 12:55 AM
  #322
i have a few pipes to chose from atm: Losi RE10/RE11, JP2, JP4, Hong nor EFRA 2047.
So wich one would be best, i know 2060 and 9901 are best but dont realy want to sped 160$ for pipe atm.
snaxez is offline
Old 10-17-2011 | 04:46 PM
  #323
RE10 or jp4 would be good
gofast072 is offline
Old 11-08-2011 | 01:32 PM
  #324
VPProUSA's Avatar
TLR Driver, Ryan Lopez, TQ's and Wins 1/8 pro buggy at the Alabama Shootout 4.0 with the Arrow-Racing GTR-21 engine.
VPProUSA is offline
Old 11-15-2011 | 07:03 PM
  #325
after doing some testing with this engine i highly recommend using a jp3 pipe on this engine
Old 11-15-2011 | 07:17 PM
  #326
Jaz240's Avatar
Did you test run times?
Jaz240 is offline
Old 11-17-2011 | 06:07 PM
  #327
ya the jp3 pick up a min over the os 2060 and powerband is spot on with the jp3 engine didnt feel good on the 2060 and the 2035 the engine is all bottom and no top and gets about the same runtime as the 2060.
Old 11-17-2011 | 09:54 PM
  #328
Jaz240's Avatar
Wow that's impressive. That's the first time I've heard of any Jammin pipes with better runtimes than anything! Great feedback. Appreciate the test results.
Jaz240 is offline
Old 11-20-2011 | 10:41 AM
  #329
photobrat's Avatar
Im about to pick up a nib "used" gtr, how can I tell if it has the updated v2 crank case, and of its v1 is that a big deal performance wise? When did this change over happen? THANKS!
photobrat is offline
Old 11-21-2011 | 04:53 AM
  #330
roblupo's Avatar
The case was changed a few months back due to the front bearing coming out really easy. If you take the engine apart, and you pull the crank out and stick a wrench in the case and hit the front bearing it will fall out.
The bad thing with this is air leaks and fuel leaks from the front bearing. Also it does not seem to have the power of a sealed engine. You can replace the bearing, or get the new case from Hobby Pro and put all the parts you have one the new case.
roblupo is offline
