Like Tree195Likes
Novarossi engines thread
Old 10-31-2011 | 08:08 AM
  #4216
Hi,
The P/S/R set for the flash .21 special and .21 PT have different part #s... 08568/10 and 08568/11 respectively.
I am just trying my luck, but would they happen to be identical?
sam
sammies is offline
Old 10-31-2011 | 12:30 PM
  #4217
Chickentrader's Avatar
Originally Posted by sammies
Hi,
sam
Keep us updated please.
Kindest regards,
Lars.
Chickentrader is offline
Old 10-31-2011 | 01:10 PM
  #4218
Grinder's Avatar
Hi,
sam
The timing, and dimensions are the same. The difference is that the PT has the hard coated piston. You can use the PT set in the Flash special, and vice versa.
Grinder is offline
Old 10-31-2011 | 01:12 PM
  #4219
Grinder's Avatar
Originally Posted by fung_kyle
If I run a Plus 12-3CT and run 20% with it, is it bad?
That will be ok.
Grinder is offline
Old 11-04-2011 | 03:53 PM
  #4220
asw7576's Avatar
I have two sydney kangooroo .21 engine, 7 ports.
After original p/s/r is dead, is it okay if I replace it with 9 ports ? ..... ( they have the same bore x stroke )
Im thinking of using 9 ports from 35plus 21 or 21 flash.
asw7576 is offline
Old 11-05-2011 | 01:40 AM
  #4221
If you get the 35+ buttonhead with it.
But do not get fooled, 9 ports does not make a difference.
Roelof is offline
Old 11-08-2011 | 03:13 PM
  #4222
Default Used Glow plug for sale.
Deleted; listing details on E-bay have been changed to new.
Kindest regards,
Lars.
Old 11-14-2011 | 09:37 AM
  #4223
When do I have to change the conrod, apart from after running certain amount of fuel through it? And how do I check for the endplay of the con rod?
Backspace. is offline
Old 11-22-2011 | 11:01 AM
  #4224
staikosn1's Avatar
Good evening people...
I'm thinking that engine guyz....
http://www.ebay.it/itm/NOVAROSSI-PLU...item3f0fb4cf25
How do you compare the Nova +12-3sct engine with RB R3 RC??
staikosn1 is offline
Old 11-22-2011 | 12:31 PM
  #4225
Default 353 08 .12
Hi All,
Q1)
I am running novarossi 353 08 .12 with 25% fuel.
After break-in, how many shim should I use?
Q2)
I am not a fast driver.........top end engine isnt a must for me and I dont need to run the engine too lean.
I am planning to get a nova N12T1 or LL3 for trainning purpose and cheaper maintance cost in long run.
Are they similar? which one is better in term of useful life.
Thank you!
R003 is offline
Old 01-03-2012 | 04:48 PM
  #4226
asw7576's Avatar
Originally Posted by R003
Hi All,
Q1)
Q2)
Thank you!
A1) to be safe, add another 0.2mm ........... actually dont use 25 percent. 16 and 20 percent is already perfect for .12 engine. The problem of using 25 percent is too hot, thus you have to richen the needle to make it running not too hot. There is a chance you will not make the 5 minute run time with 25 percent nitro as consequences. ( I'm assuming you have same number of laps with other racers ).
A2) no need to buy another engine. Use that engine for 5 to 6 races, and sell it away. Buy a new engine again after that. Tips: 1). Never overheat your engine, the piston head surface will damage. Keep it running between 110 - 120 Celcius. 2). Never overheat your engine, you might end up with glow plug's element melted and ruined the piston sleeve. 3). Always clean the piston sleeve and give plenty after run oil after use.
asw7576 is offline
Old 01-08-2012 | 08:57 PM
  #4227
lil-bump's Avatar
Anyone know the front bearing size on the Nova 3sct.
Pass you soon...
lil-bump is offline
Old 01-09-2012 | 05:07 AM
  #4228
Pass you soon...
part# 16605
http://www.novarossi.it/files/explod...2-3ST_3SCT.pdf
desotoracing is offline
Old 01-09-2012 | 05:50 PM
  #4229
Pass you soon...
The take look at the chart in the file insert.
Kindest regards,
Lars.
File Type: pdf
Old 01-09-2012 | 06:57 PM
  #4230
lil-bump's Avatar
Thanks for the info. For some odd reason everytime I try to access the Novarossi site. My antivirus program blocks it because of a malicious cookie:confused :
Pass you soon...
lil-bump is offline
