Serpent 811E Buggy Thread
#617
Very Nice wire/soder Job. A car never looks better than the new build pre-track visit.
I thought so too. I stiffened up the front springs and lightened the rear and I feel its more balanced for my driving style.
#618
Everyone is saying they stiffened the front and softened the rear, but am I alone when I say mine felt like the car already transfers a lot of weight to the rear on power? Also the front doesn't drop fast enough on corner entry. I've been thinking of going thicker on the rear oil and softer on the front spring. I have seen more than one person post that the front tires blow up on power. Mine has 7000 in the center diff and still blows up the front tires. I run on a medium to high bite indoor track and I think 7000 in fine in the center, I just need to get the car to transfer the weight to the rear slower on power.
#619
#623
#624
Because of the greater amount of weight in the front when it transfers it transfers alot. Not like a typical buggy where most of the weight is in the middle so it takes a lot more to transfer the same amount. It's a different concept but play around with it. You will see it on the track. When I went soft in the rear and stiff in the front I had pizza cutters on the front. Once I stiffened up the rear sprigs the pizza cutters went away. With the soft springs in the back the front was up high and it behaved more like a 2wd which is what made the rear so loose. Even with the serpet white sprigs on the rear my car still pulls wheelies on the street if I pull the trigger too hard because of all the rear traction. Mess around with it, it takes a little bit to get use to how this buggy responds.
#628
5Likes
