Picco TORQUE versus Novarossi topic >
Old 10-31-2011 | 04:14 AM
  #31
wingracer's Avatar
Originally Posted by Brent Davis
Wingracer, are you currently still running your Picco TQ engine?
I ran it at the nats, it was fantastic. Nitro season is over now though
wingracer is offline
Old 10-31-2011 | 05:29 AM
  #32
stefan's Avatar
Originally Posted by Roelof
Crankshaft opening and intake are different (much larger) than Novarossi.
See the many Novarossi models and the one Picco:
http://www.euronet.nl/users/tooms/timings/timings.jpg
I just measured our Torque Edo (2 of them) and both cranks open at 28 ° and close at 35°
stefan is offline
Old 10-31-2011 | 06:57 AM
  #33
Was this in a MRX5? How do you compare the bottom end/mid range power to your 35plus21 engines? I mean is it really that much more noticeable from what I have heard? I'm liking this engine on the bench right now and hope it will definately turn some heads.
I took mine apart and noticed that the rod is definately longer than the R7 rods used in the 35 plus and Kangaroos as well which in turn will help produce more bottom end power as well.
Brent Davis is offline
Old 10-31-2011 | 07:04 AM
  #34
Stefan, this will allow more fuel to enter into the engine sooner but also closes later than the Kangaroo cranks which should in turn produce more HP.
Stefan, how do you like the Picco TQ engine?
Old 10-31-2011 | 07:11 AM
  #35
wingracer's Avatar
No, Shepherd (though a Mugen clutch).
My 35+21 felt like it might have had a bit more in the middle range but the Picco felt better on the bottom and oddly on the top as well. At least until I tried my old standby 9886 pipe on it which seemed to make the top fall flat for some reason so I went back to the 2013.
Old 10-31-2011 | 07:40 AM
  #36
Was the Picco fairly easy on the tune up as well? Was this feel from the 35 plus to the Picco with same gearing and such for a fair comparison?
Old 10-31-2011 | 07:56 AM
  #37
Originally Posted by spdmkr
Hi Brent
I am the Picco USA distributor for Torque line engines.
You can find us at www.kevcoracing.com or email me at [email protected]
Kevin Hutchinson
Kevin, thanks for the link. I saw where you offer the rods for replacement for the .21 TQ engine. I want to know what is the difference between a standard rod and the modified version rod that is listed on the site? Also are crankshafts available for this engine as well?
Old 10-31-2011 | 07:59 AM
  #38
wingracer's Avatar
Yes, same gearing and clutch set-up.
Motor was very easy to tune and held it all through the week. No flameouts except for the couple times I ran it out of fuel. No detonation and no destroyed plugs.
Old 10-31-2011 | 08:15 AM
  #39
PERFECT! Thanks for your input and data. It encourages my decision even more to know that you do like it.
Old 10-31-2011 | 12:11 PM
  #40
stefan's Avatar
Hi Brent, I know about the timing. Roelof has posted engine timing a bit further down. where the Torque is listed with 30 -70 = 220° crank timing, which looked strange, especially in light of the awesome fuel consumption of these engines.
So I measured mine, and the are different.
I love the Torques, aside from some bearing problems we had early in the year.
It seems that it was only one of the very early batches (January -February) because later engines didn't have that problem.
The thing you need to get used to is the very low compression these engines seem to have when they are cold.
Some guys wanted to trash them, despite they were running awesome.
Just old Nova habits
The Torque has a different piston material that seems to expand when the engine gets to operating temps and then works great.
Very easy to break in and easy on the rods.
stefan is offline
Old 10-31-2011 | 01:45 PM
  #41
The 30 is normal but the 70 looks indeed strange but i did checked it twice. Beside that with most engies and things I have tryed a 65 up to 67 degrees is not strange but indeed fuel consuming.
The only thing I can imagine is that this guy has many Torque engines, part sponsored and part bought and probably has mixed a crankcase with a different crankshaft.
Roelof is offline
Old 11-01-2011 | 04:04 AM
  #42
Lol, I know you know about the timing and all, I was just saying in simple terms for those that may be reading, what your information meant.
What was your timing measurements on your compared to what Roelof posted? Now from those numbers though and what I measured on my Kangaroo, the Torque definately should make more HP and RPM's up top. The exhaust timing could be a little higher for more top end RPM but I am not so sure that the bottom end would suffer from raising it though.
Old 11-01-2011 | 04:46 AM
  #43
stefan's Avatar
Hi Brent,
we have raised the sleeve on a Torque by 0.1 and 0.2 mm in order to gain top end.
We did, but it hurt the fuel consumption.
I rather gear the Piccos a bit longer than Novas to get the same top speed.
What also helped to gain some revs w/o hurting fuel consumption is using the Nova medium conical header with the Picco 2033 pipe.
My son is still running with a pretty smooth gas finger (will probably be spoiled soon) and he makes 5 minutes with the Torque, doing the same lap times as other people who run NR Flash and only make 3:30.
This has given us the edge in several races this year and I will try to conserv that advantage as long as possible.
Once he is going completely "point & shoot" and won't make the 5 min anymore, I will start modding the Torque towards top end...
stefan is offline
Old 11-01-2011 | 05:11 AM
  #44
I think many people will switch to Picco if the EFRA AGM will decide to go back to 5 minutes qualify without fuelstops. Next saturday we will know....
Roelof is offline
Old 11-01-2011 | 10:00 AM
  #45
MRX4XXXX's Avatar
.. That's what we are waiting for(the information), to know what to buy for next summer.
-X-
MRX4XXXX is offline
