Serpent 811E Buggy Thread >
Like Tree5Likes
Old 10-28-2011 | 09:37 AM
  #511
porkchop's Avatar
i have ran the same top plate on my nitro buggy for gallons and i never glued it
porkchop is offline
Old 10-28-2011 | 10:22 AM
  #512
Frank L's Avatar
Man I just can't contain myself when a new kit arrives. My E kit was at the mailbox tues last week and I rolled it up and down the street at 2am wed. The durango came 12/24 and i raced it 12/26. I guess I just done have the self control that you guys do. If its in my bench I gotta put it together and see what it can do.
Frank L is offline
Old 10-28-2011 | 11:22 AM
  #513
Bonadona's Avatar
I don't see doing the top plate for added strength, but just to make all the carbon pieces match.
Bonadona is offline
Old 10-28-2011 | 11:30 AM
  #514
Cmjomaha's Avatar
Originally Posted by Bonadona
The process to sanding the shock towers is simple. But don't just to the towers, do the carbon steering top mount as well. Just sand the edges with 400 grit sandpaper to knock off the rough spots then go over them with 800-1000 grit to smooth them out. After that I like to take a black sharpie marker and go over everything I just sanded (the edges). Finally get a couple of q-tips to apply the glue. I've done a ton of Touring Car kits and nothing works better than super thin finger nail glue from your local CVS or Wallgreen's. All tire CA type glues are thicker than nail glue. The one I use is called Jet Dry. 2 bottles to a pack for like $3. Wet the q-tip with glue and make smooth strokes abound the edges. When the q-tip starts to smoke from the fast drying activators, throw it away and start with a new q-tip. If you use the sharpie before glueing it leaves a nice shiny black "piano" Finnish.
Thanks very much!!!! I will be following this recipe...
Cmjomaha is offline
Old 10-28-2011 | 11:50 AM
  #515
Originally Posted by IanB
Ran mine with the transponder on the mount under the ESC and had issues with it not picking up !
Maybe why the instruction book refers to having it on the servo instead
Awesome car though well balanced and handling is very well balanced
Also had problems with the transponder not being picked up with it mounted under the ESC. But, I had the numbers facing down. Will try it again with the numbers facing up and see how it works.
Stealth_RT is offline
Old 10-28-2011 | 12:03 PM
  #516
Frank L's Avatar
When I ran a losi I use to put the transponder in the same box as the the receiver and as long as it was horizontal with the #'s up I never had an issue.
Frank L is offline
Old 10-28-2011 | 02:13 PM
  #517
I didn't try turning transponder up the other way due to lack of time and need to get timed qualifier in ! Ended up with a B qualifier and bumped to the A
Fitted a smaller MRT cloned transponder that sits flat next to the servo on the sideguard which seems to have cured the problem now
Will try refitting the AMB under the ESC other way up and see what happens next meeting
IanB is offline
Old 10-28-2011 | 02:44 PM
  #518
joel804's Avatar
Well I got my buggy Last monday and finaly no kids and the chores are done LOL. So I just got it soldered up (and yes thats the elusive 3 hole rx8 with black heatsink on vegas 212) Please excuse the messy work bench
joel804 is offline
Old 10-28-2011 | 02:49 PM
  #519
bigjayjay1's Avatar
Looks good buddy always great finishing a build very satisfying you know its done correctly well at least U hope
bigjayjay1 is offline
Old 10-28-2011 | 02:57 PM
  #520
joel804's Avatar
Thanks bigjay. I hope to get it on the track this sunday.
joel804 is offline
Old 10-28-2011 | 03:01 PM
  #521
joel804's Avatar
And the body art or lack of there of LOL still working on it
joel804 is offline
Old 10-28-2011 | 03:38 PM
  #522
Frank L's Avatar
Looking good guys.
I'm headed to the track tomorrow to try a few tips that Billy Easton passed down like making the rear springs stiff. I'll post up my findings after.
Frank L is offline
Old 10-28-2011 | 07:28 PM
  #523
joel804's Avatar
YEAH BABY
joel804 is offline
Old 10-28-2011 | 07:34 PM
  #524
joel804's Avatar
At the max width the RC8 body is 1.5" wider
joel804 is offline
Old 10-28-2011 | 09:14 PM
  #525
Originally Posted by Randy_Pike
Guys 12 gauge wires is more than sufficient for these cars. I will strongly suggest NOT using bullet connectors on your motor wires. The amp draw is often over the rating of the connectors and should one of those come off during a run it will be very bad.
So I take it the soon to be released LRP iX8 with bullet connectors directly onto the esc would not be a good idea? I don't want any bashing of other peoples products but some open views to help me make up my mind as to what esc to use. Is the LRP more aimed at the bashing market?
I do understand that if one of the connectors would open then the motor would effectively lose a phase and go into shunt causing very high temps and vibration. But some connectors are very good.
Badger5 is offline
