Like Tree5Likes
SC10 4x4 Thread
Old 10-25-2011 | 08:44 AM
  #9421
Divey's Avatar
Originally Posted by 1Fastpede
its not needed.
Ok thanks.
Divey is offline
Old 10-25-2011 | 08:55 AM
  #9422
CraigMBA's Avatar
Originally Posted by CoyoteSlash
I've blown two idlers with all stock slipper gear. So I really "really" don't believe that a basket is necessary. It allowed for good tunability with the three pads. But if you're pinned, That tuning just went bye bye.
The point of using the slipper basket with the pin modification is to increase the clamping power of the slipper with more surface area from the additional pad, allowing you to run the setup looser so that it saves the driveline parts, yet not so loose that you lose performance or smoke the slipper. Plus you have more finite adjustment.
That's why I said I'd run three HD pads. I bought a pair of idlers just because other users claim they've broke them for spares, but after three months, I still haven't broke anything on this truck.
I did knock a tie rod off during practice on Sunday if that counts. Stay off the fence!
CraigMBA is offline
Old 10-25-2011 | 09:32 AM
  #9423
SourDieselX's Avatar
with the pin mod, I did actually lose a single tooth on my idler gear, mantis was able to see it first hand, but since changing it out it's fine and no issues as of now.
SourDieselX is offline
Old 10-25-2011 | 09:35 AM
  #9424
Cain's Avatar
so what is the verdict then if you go with the pin mod and the clutch basket as far as the number and type of pads to use?
Cain is offline
Old 10-25-2011 | 09:45 AM
  #9425
I don't even bother with the basket, while some like it, I like the current setup that I have right now, the pin mod with the rcshox garodiscs, with the combination together it is really nice, stays planted and provides great forward motion.
Old 10-25-2011 | 09:55 AM
  #9426
1Fastpede's Avatar
i run 3 hd pads in the basket with the pin. no issues.
Sour aren't you running a tekin pro4? maybe that's why your idler gear decided to give up. lol
1Fastpede is offline
Old 10-25-2011 | 10:02 AM
  #9427
I am running a pro4 4600kv, lol. but it's dialed back a lot, at 100% this motor is crazy in our trucks.
Old 10-25-2011 | 10:07 AM
  #9428
Mizchief's Avatar
Losi guys are starting to get frustrated at me being able to get inside of them, shoot out and 'gone' on every. corner. hehe... They're starting to try and duplicate it with hilarious results. They're great sports though.
Yea, heavier trucks make better berms!
Mizchief is offline
Old 10-25-2011 | 10:09 AM
  #9429
Mizchief's Avatar
Originally Posted by CraigMBA
See? I wouldn't steer you guys wrong.
Unless you are running a 540 motor 5.5 or less I would buy the Mac The Knife clutch basket and run 3 HD pads in it. That's not exactly right. You should run one then too, but you might be able to slide by without it if you run that little motor.
The neat thing about 550's in this truck is they don't heat. You can run 15 minutes in 100 degree temps full punch and the motor comes off like 140 or so. Might be the same reason the truck doesn't use batteries like the other ones do.
Yep, ran a full 5000mah on grass the other day and motor came back at 120, was about 75 degs at the time. My esc has yet to peak 100deg.
Mizchief is offline
Old 10-25-2011 | 10:12 AM
  #9430
Mizchief's Avatar
Originally Posted by BLbound
They are worth their c rating! Lotsa puncha!
What's the biggest one you can fit in the truck without mods? Don't care about hard case or ROAR, already got an approved batt for racing but want more runtime for practice.
Mizchief is offline
Old 10-25-2011 | 10:18 AM
  #9431
Chad Smith's Avatar
I think a couple people have bought the Hot Racing Diffs. How are they holding up? Are they getting super wobbly (assuming you limited uptravel). Does it look like any oil is leaking out of them?
Chad Smith is offline
Old 10-25-2011 | 10:54 AM
  #9432
On a side note, I can now change the front diff, which includes cleaning out the gears and re-assemble in about 30mins. Think I can get that down to 20 mins or so with a power tool. Nothing else owning this truck has made me 100 x more mechanically inclined.
GuiltyByAssoc is offline
Old 10-25-2011 | 11:21 AM
  #9433
murky123's Avatar
So when you have the topshaft pinned, and you have no option for a basket or any other exotic slipperpads.
what is the best slipper setup without destroing the idler gear?
Just run the pinned shaft and use the AE HD-pads on the inside and outside?
will that be enough to keep the idler gear in shape and keep the "acceleration" or will you have to run the slipper to loose, so that the trucks loses his "acceleration"
Im running pinned, have no basked and no exotic pads, but my old jammin still has better acceleration.
I guess I must be doing something wrong, but what? ( dont wanne destroy idler gears )
murky123 is offline
Old 10-25-2011 | 11:47 AM
  #9434
Kevin Boyle's Avatar
Hey Guys,
I am new to the thread and I wanted to ask a few basic questions about tweaks that have been made to your SC10 4x4.
1) Battery placement- from what I have read the best place to have the battery is forward and using a saddle back does the trick. Correct
2) Slipper issues, what happened? My SC10 4x4 is on order this week and I would like to build it correct the first time.
Kevin Boyle
Kevin Boyle is offline
Old 10-25-2011 | 11:55 AM
  #9435
Originally Posted by Kevin Boyle
Hey Guys,
Kevin Boyle
it's not to say there is anything wrong per-say, but the upgraded garodiscs are much stronger, rcshox makes an excellent set.
