SC10 4x4 Thread
#8851
Dang really marcus 10 up front.
Just got the thing put back together from pinning it, now I have to rip it apart to switch out the front diff oil .....
oh well back to the garage .
Glad I have the day off to wrench on it , was hoping to go run some packs through it. Only packs i will be running today will be through my hitachi R&R ing screws
got anything else for me before I put it back together
Thanks for all the imput and time you all have invested and share the results with the rest of us.
J
J
#8852
Not sure why anyone would not do the pin mod. Once the parts are modified the truck goes back together with or with out the pin installed. If you don't like the pinned set-up then remove the pin and enjoy your new lightened top shaft.
#8858
Krio,
Most of the guys I run with are going with spacers under the camber links to avoid that rolling or 'tripping' as you call it, rather than adjusting the camber to such a great angle.
Also replacing those front BLUE springs with YELLOW will help that problem.
I was pretty sure that you were talking about an outdoor track that you were running at just above here? Dakota's track is INDOORS? Impressive to have an indoor facility at your home (or Dakota's)!
If you are talking about more than one track, well...you should know that you'll have to change your set-up to the track. So I must be mistaken somehow in thinking we are talking about more than 1 track/situation.
#8860
#8861
#8863
#8864
5Likes
