RC10B4.1 FT/WC
Old 09-24-2011 | 07:30 PM
  #6091
Default HELP WITH PERFECT TRACK GEEARING!!!
IM RUNNING A LRP V7.1 W/ TRINITY D3 7T MOTOR W/ A 87 SPUR GEAR ON MY T4 WHAT PINION GEAR SHOULD RUN SO I DONT BURN UP MY MOTOR ETC THANKS GUYSSSSSS
jrthestar is offline
Old 09-24-2011 | 07:58 PM
  #6092
Jake S's Avatar
v7.1? brushed? 7t is WAYYY too much motor lol. a brushless 7.5t is not equal to a 7t brushed.
ordered some pinons and another spur, so i have 75, 78, 81, 84 spurs, and 22t 24t 26t 28t 30t pinons, hopefully i can get a gear ratio that works
most likely going to start with 78/24 with a 10.5 in buggy and 84/22 on the 9.5 in the t4, unless anyone has other comments.
Jake S is offline
Old 09-24-2011 | 10:30 PM
  #6093
Wild Cherry's Avatar
15t pinion
Wild Cherry is offline
Old 09-24-2011 | 10:31 PM
  #6094
yeh i have a brushed 7t single motor with 87t spur and 15t pinion hawlsssssssssss assssssssssssss but i dont wanna burn it up so i wanted to no what would be a good gearing ratio for it
Old 09-24-2011 | 10:48 PM
  #6095
Default Maintenance
tip
*don't run it much longer than 5 min
* turn the com & replace brush's after 2 or 3 runs...
Old 09-25-2011 | 10:17 AM
  #6096
tip
how long should i leave my motor cool down between runs?
Old 09-25-2011 | 10:25 AM
  #6097
How long ?
Till it has cooled off....(15<>20 min)
Old 09-25-2011 | 02:17 PM
  #6098
RickSlick's Avatar
Default V2 shocks
Just ordered front and rear V2 shocks for my B4.1 which is currently stock.
I run at an outdoor clay track with a good mix of bumps, straights and jumps.
What is a good weight of oil to start with for the fronts and rears in these shocks? Also, I ordered a variety pack of springs, what springs should I start with also?
Thanks all....Rick
RickSlick is offline
Old 09-25-2011 | 02:48 PM
  #6099
Jake S's Avatar
Thanks all....Rick
http://teamassociated.com/setupsheets/RC10B4.1/
Jake S is offline
Old 09-25-2011 | 03:43 PM
  #6100
Default b4.1 +8 chassis
would the +8 chassis make a big difference on the handling of the buggy and also getting diff rebuilt with bfast balls and rings make a big difference what kind of balls should i get?
belliso is offline
Old 09-25-2011 | 03:45 PM
  #6101
Default b4.1 shocks
would the kyosho velvet shocks be better on b4.1 than the orignal shocks ?
belliso is offline
Old 09-25-2011 | 04:07 PM
  #6102
Jmuck69's Avatar
+1 on the 8mm chassis, makes it handle like night and day.
The Bfast Kit is a waste. You can achieve the same results sanding your stock rings and using ceramic diff balls. Others on here will argue with this, but that is them.
Jmuck69 is offline
Old 09-25-2011 | 04:08 PM
  #6103
Jmuck69's Avatar
The V2's are great shocks and work great.
Jmuck69 is offline
Old 09-25-2011 | 04:51 PM
  #6104
idrummerboy13's Avatar
Default blue speaker wire
hey guys currently looking for blue speaker wire to put on the lrp, would a 50 watt soldering iron work? I should i use a gun my bud has? \
http://www.amazon.com/COMPLETE-ENCLO...994928&sr=1-98
this ok?
idrummerboy13 is offline
Old 09-25-2011 | 05:20 PM
  #6105
ovalracer1m's Avatar
this ok?
50 watt should be ok. I have used a 40 watt iron in the past and did an ok job but not ideal.
ovalracer1m is offline
