Like Tree5Likes
SC10 4x4 Thread
Old 09-25-2011 | 02:44 AM
  #7741
CraigMBA's Avatar
Originally Posted by T-BirdJunkie
Let's all rush to buy the hot new Associated 3 piece wheels for our RC10s!
The rears sucked but the fronts were awesome. Even the Losi factory guys used to run AE wheels in the steer position before the XX came out.
CraigMBA is offline
Old 09-25-2011 | 02:52 AM
  #7742
CraigMBA's Avatar
Originally Posted by tony montana
anyone use the novak havok pro sc with the 4.5 550 motor? If so any problems with it in this truck
That's what I run. I have a ton of usable rip with this combo. I added another fan for the motor, but after ten minutes the hottest I've got it is 120 degrees. Fitting the fan under the belt tunnel is a little tough, but not a deal breaker.
So, no problems, and I've never been passed in a straight line with the 4.5 550. Ever. I even run the kit pinion that Novak sent in the AE package.
CraigMBA is offline
Old 09-25-2011 | 02:54 AM
  #7743
Divey's Avatar
I am about to buy one and wanted to share my list so far. Is there anything else I should need that is a must part. No light weight or racer parts cause I just race in my backyard track and bash. Since the coupon code is 599$ and save 150$, I still have a little left. Trying to stay around 450-500$ total and shipping of course is free. Let me know what you think.
Stock Number Manufacturer and Product Description Order Qty Ship Qty Back Order Qty Price Each Remove From Cart
LXAXLK Associated 1/10 SC10 4x4 Team Short Course Kit
1 $ 269.97
LXBAXB Associated Factory Team Rear Swaybar Set 4x4
1 $ 19.19
LXBAXA Associated FT Front Swaybar Set 4x4
1 $ 18.29
TKRC1656 Tekno R/C Aluminum Hex Adapter 12mm M6 Driveshaft Slash
1 $ 18.59
LXXWH5 Castle Creations 1/10 Mamba Max Pro ESC Smart Sense
1 $ 127.98
LXSWL3 Castle Creations CC BEC 10A 6S Switching Regulator
1 $ 21.99
LXBAPL Associated Steering/Caster Block SC10 4x4
1 $ 6.79
ASCC1032 Associated Rear Hub Carrier SC10 4x4
1 $ 3.99
ASCC1076 Associated Spring Front 13mm 4.8 lb Yellow
1 $ 4.89
LXBASV Associated Spring Rear 13mm 3.1 lb Yellow
1 $ 4.89
ASCC1170 Associated Factory Team High Torque Slipper Pad
1 $ 6.79
LXVCW8 Robinson Racing Xtra Hard 5mm 8 Mod Pinion 13T
1 $ 11.69
LXVCW9 Robinson Racing Xtra Hard 5mm 8 Mod Pinion 14T
1 $ 11.69
LXSGZ2 Traxxas Nuts 4mm Flanged Nylon Locking Steel (8)
1 $ 3.25
014DH SAVE $150 on $599.90 ORDER
Applied during checkout process if this order In-Stock Items:
$ 529.99
Back Orders: $ .00
Combined: $ 529.99
EBAY- Castle Creations 1/10 SC 4 POLE MOTOR 3800KV 1410-1Y
$59.95
That's it so far. I have a servo already. Anything else that is a must part please let me know before I make the order.
Sept 2011 Tower Hobby Codes:
$100-$149.99 $20 014DA
$150-$199.99 $30 014DB
$200-$249.99 $45 014DC
$250-$299.99 $60 014DD
$300-$399.99 $75 014DE
$400-$499.99 $100 014DF
$500-$599.99 $125 014DG
$600-$699.99 $150 014DH
$700-$799.99 $175 014DJ
$800-$899.99 $200 014DK
$900-$999.99 $225 014DL
$1000 or more $250 014DM
Divey is offline
Old 09-25-2011 | 04:10 AM
  #7744
Artikbot's Avatar
Do you have tires?
If not, get at least a set of AKA Enduro in soft compound. Maybe medium, depending on hoy many clay you run.
Artikbot is offline
Old 09-25-2011 | 05:12 AM
  #7745
tony montana's Avatar
ok I decided on the novak havok system with the 550 4.5. I also found a lipo that is a 5000 mah 40c, will that battery get the job done? Also I need to order pinion gears. Confused here, Do I need like the 32 pitch novak mod 1 5mm's? If so, what number of teeth should I start with
tony montana is online now
Old 09-25-2011 | 05:15 AM
  #7746
Yeti AS3's Avatar
I would get the AE hexes over Tekno so you don't have to play wiith shims. Pick up Mac The Knife's clutch basket.
Yeti AS3 is offline
Old 09-25-2011 | 06:46 AM
  #7747
Vegatron75's Avatar
Hit the big outdoor track yesterday. Truck was feeling real nice. Using the RCShox 2-stage pistons made a world of difference.
Running 30f/25r, yellow springs F, blue R. Stock size holes in the pistons, middle tower, outer arm. 2.0 sway F, no sway rear. Removed saddle packs and went back to stick packs.
I was also using the 19t front pulley, makes a nice difference w/ the extra front pull.
Truck was fast and planted. Would settle on approach instantly. Had excellent rebound and would stay in control through the fast rough sections.
The 2-stage pistons are awesome. So much better feeling than the stockers. I was also running the RCSHOX slipper pads. Never had to touch the slipper all day! Super consistent slip and no fade.
All in all... RCSHOX 2-stage pistons and slipper pads are the bomb. Saddle pack set-up, not so much. My truck and me work a ton better w/ the stick packs, for whatever reason.....
Vegatron75 is offline
Old 09-25-2011 | 07:50 AM
  #7748
Divey's Avatar
Originally Posted by Artikbot
Do you have tires?
Not yet but I will find those here since deals can be made. No clay for me, just regular dirt.
Divey is offline
Old 09-25-2011 | 08:55 AM
  #7749
SCTDan's Avatar
I moved my battery to the center line so left and right weights are the same with a rear weight bias. Really works well for me. I also tried 37.5wt oil front and rear with the 2 stage pistons. Our track is tight blue groove with no big jumps and heavier oil keeps it so planted it's crazy. Cut 1.5 - 2 sec off my lap times for a 25-30 sec lap track.
SCTDan is offline
Old 09-25-2011 | 09:04 AM
  #7750
1Fastpede's Avatar
1 $ 269.97
1 $ 19.19
1 $ 18.29
1 $ 18.59
1 $ 127.98
1 $ 21.99
1 $ 6.79
1 $ 3.99
1 $ 4.89
1 $ 4.89
1 $ 6.79
1 $ 11.69
1 $ 11.69
1 $ 3.25
$ 529.99
Back Orders: $ .00
Combined: $ 529.99
$59.95
Skip the tekno's and just get these: and save 4 bux
http://www3.towerhobbies.com/cgi-bin...&I=LXBLGJ&P=ML
And skip those Robinson pinions. those are not correct.
here:
http://www3.towerhobbies.com/cgi-bin...?&I=LXBAWD&P=7
and
http://www3.towerhobbies.com/cgi-bin...?&I=LXBAWE&P=7
With the money saved add frt and rear arms and extra 62T spur.
I'd also get an extra belt.(not that there is a problem but its a good spare to have.)
http://www3.towerhobbies.com/cgi-bin...&I=LXBATJ&P=ML
I just broke one of these last night: http://www3.towerhobbies.com/cgi-bin...1051&search=Go
1Fastpede is offline
Old 09-25-2011 | 09:14 AM
  #7751
Divey's Avatar
here:
and
Perfect, thanks bro. Are the arms easy to break or do they wear out like there truggies/buggies do. Anything else you can think of before I make this order.
Terry
Divey is offline
Old 09-25-2011 | 09:22 AM
  #7752
1Fastpede's Avatar
Terry
I haven't broke one yet. but after 4months they seem to have a slight bow in them.
I'd throw in some diff seals and cva pins.
http://www3.towerhobbies.com/cgi-bin...?&I=LXBARE&P=7
2 or 4 of these:
http://www3.towerhobbies.com/cgi-bin...?&I=LXXCX4&P=7
And you might need a servo extension wire.
Tires??
Old 09-25-2011 | 09:30 AM
  #7753
CraigMBA's Avatar
I would buy this combo the (the 3119) because comes with a free 12 tooth pinion - that I run everywhere.
http://www.teamnovak.com/products/br...550/index.html
Not to give you something else to consider, but you could run this and save a few bucks:
The only thing you are giving up in the GTB2 vs the Havoc that you might possibly miss is the timing function but only on a giant 1/8 scale track, and the fan.
CraigMBA is offline
Old 09-25-2011 | 09:52 AM
  #7754
nmdesertracer's Avatar
Unhappy
[B]
Your discount codes didnt work for me...
nmdesertracer is offline
Old 09-25-2011 | 10:11 AM
  #7755
yeah where the hell did you get those codes??? some of those savings are nuts +20% off?????
Keeferton is offline
