Team Orion Engines
#1021
#1022
#1023
nice link repete! that's exactly it, it's a must...
Scotty is pretty much right, any thick grease will probably work. We use this for everything:
http://www.amainhobbies.com/product_...G-Joint-Grease
#1024
Nice advise pitpop.
I see some that they always take the engine apart then cleans it, they constantly do this every after race. Are they doing it right or just messing up the engine?. Also when do i need to change my con rod on the ck ed. Im already running alsmost 2 gallons?
Your conrod doesn't need to be changed, just race and have fun.
#1025
Hey Guys. Just noticing that the US supply of these engines seem to finally have hit the market. I'm still shocked at the price considering what I know about the quality of the engines AND the pipe is included.
http://www.amainhobbies.com/product_...bo-w-2058-Pipe
#1026
Hi, Pitpop , i have a Team Orion Cody king, so just to check
What total size headshims you use (mine came with somes and the total is 0,9mm) i am using 30% nitro , 2058 pipe and 7,0mm carb restrictor
also how about your settings for low needle , high...,(of corse settings for use in race) i know this settings can vary but its just to know if mine is so different....
How about the lenght for preassure line
#1028
Calling all the people with the micheal truhe edition engine. I have a question when i was tearing down my motor. I noticed during the compression stroke the piston skirt totally clears the exhaust port about 1 mm maybe more. I am have tuning problems for a while. The motor only has 2 gals on it. There is no slop in rod, bearings are butter smooth. I have own alot of motors and never had a piston do this. The piston is great shape. And the skirt is not broken.
#1029
#1034
6Likes
