Like Tree6Likes
Team Orion Engines
Old 08-23-2011 | 10:51 PM
  #1021
Originally Posted by jewn_beef
Huh grease on inner filter ends what kind i do not do that butwill start
http://www.tytessmann.com/tips/airfilter_greasing.html
RePeTe is offline
Old 08-24-2011 | 05:21 AM
  #1022
ScottyM's Avatar
I'm going to assume that any kind of "GREASE" will work. I too am going to start doing this. It never even occured to me this could be a problem.
ScottyM is offline
Old 08-24-2011 | 10:08 AM
  #1023
pitpop's Avatar
nice link repete! that's exactly it, it's a must...
Scotty is pretty much right, any thick grease will probably work. We use this for everything:
http://www.amainhobbies.com/product_...G-Joint-Grease
pitpop is offline
Old 08-24-2011 | 10:16 AM
  #1024
pitpop's Avatar
Originally Posted by elkapitan
Nice advise pitpop.
I see some that they always take the engine apart then cleans it, they constantly do this every after race. Are they doing it right or just messing up the engine?. Also when do i need to change my con rod on the ck ed. Im already running alsmost 2 gallons?
Yes, I would say always taking your engine apart is not a real good idea, unless you just want to do it for fun. I look at the dis-assembly of an engine as a process, and a serious commitment. If you take an engine apart, you have to take it all the way apart, clean and lube all the parts in a sterile environment, and then carefully put it back together. Not something I take lightly, and I have had engines run a long long time without being opened up. Just clean the outside and take care of the air filter and clutch.
Your conrod doesn't need to be changed, just race and have fun.
pitpop is offline
Old 08-25-2011 | 08:29 AM
  #1025
pitpop's Avatar
Hey Guys. Just noticing that the US supply of these engines seem to finally have hit the market. I'm still shocked at the price considering what I know about the quality of the engines AND the pipe is included.
http://www.amainhobbies.com/product_...bo-w-2058-Pipe
pitpop is offline
Old 08-26-2011 | 11:51 AM
  #1026
Hi, Pitpop , i have a Team Orion Cody king, so just to check
What total size headshims you use (mine came with somes and the total is 0,9mm) i am using 30% nitro , 2058 pipe and 7,0mm carb restrictor
also how about your settings for low needle , high...,(of corse settings for use in race) i know this settings can vary but its just to know if mine is so different....
How about the lenght for preassure line
Marco23 is offline
Old 08-27-2011 | 02:56 PM
  #1027
lee_double2000's Avatar
Default question
I was wondering what will cause my Truhe Orion .21 motor to flame out after pit-stop?? It runs fine all race but after pit less than a min later it will flame. Any solution? Advice? Thanks
lee_double2000 is offline
Old 08-27-2011 | 06:59 PM
  #1028
stallen50's Avatar
Calling all the people with the micheal truhe edition engine. I have a question when i was tearing down my motor. I noticed during the compression stroke the piston skirt totally clears the exhaust port about 1 mm maybe more. I am have tuning problems for a while. The motor only has 2 gals on it. There is no slop in rod, bearings are butter smooth. I have own alot of motors and never had a piston do this. The piston is great shape. And the skirt is not broken.
stallen50 is offline
Old 08-27-2011 | 07:26 PM
  #1029
Maximo's Avatar
a piston skirt should not clear the exhaust port....have you broken your piston ?
Maximo is offline
Old 08-27-2011 | 07:39 PM
  #1030
I know this is Orion thread but my Werks B5 is doing the same thing. If anyone has a solution it would be cool or any ideas.
Corey Jones is offline
Old 08-27-2011 | 07:45 PM
  #1031
I think he may have modded (broken) the piston skirt off by
pulling the back plate off when the piston was at b.d.c., huh?
rageworks is offline
Old 08-27-2011 | 10:01 PM
  #1032
stallen50's Avatar
Piston is fine. The skirt is not broke.
Old 08-28-2011 | 10:31 AM
  #1033
v6shooter's Avatar
Any pics
v6shooter is offline
Old 08-28-2011 | 11:04 AM
  #1034
Maximo's Avatar
That mean the engine is flooding out on refuel...Lean the needles slightly, use hotter glowplug, fill tank less......
Maximo is offline
Old 08-28-2011 | 11:05 AM
  #1035
Maximo's Avatar
take some pics if you could please.... The piston should not clear the exhaust port, so something is not right..
Maximo is offline
