Like Tree195Likes
Novarossi engines thread
Old 08-24-2011 | 02:24 AM
  #4126
The 353 is just an older model. I think both will be very competive.
Roelof is offline
Old 08-24-2011 | 02:44 AM
  #4127
oww ok, i noticed in the pictures on the nova site the 3T had no boost port under the exhaust outlet whilst the 353 tuned had two.
Also i heard that the new nova .12PT (and the S) series is not reliable have people found this to be true?
TomB is offline
Old 08-24-2011 | 03:43 AM
  #4128
Those are no boost ports, they are only used to splash some cold fuel against the piston to cool down the hottest side of it.
About the reliabillity I can not tell.
Roelof is offline
Old 08-24-2011 | 04:04 AM
  #4129
oww ok great, so i'm correct in assuming the 353 .12C tuned has the holes under the ex port whilst the flash .123T doesn't. I was also told via PM that the flash .123T has slightly better torque and more run time than the 353
TomB is offline
Old 08-24-2011 | 04:18 AM
  #4130
howardns's Avatar
i have both, i started our last season in florida with the 353 and switched the end of year to the 12pt. for me both made 5 min. to me the 12pt has more bottom and midrange than the 353. On the tracks that i ran the 12pt i ran faster and more consistant lap times than with the 353. i have run almost 2 gal thru and no problems. I do not know anybody who had problems with the 12pt.
howardns is offline
Old 08-25-2011 | 04:24 AM
  #4131
If I remember correctly, I was looking at the parts list for both the Flash .12 (not PT) and the Flash .12 PT, and they both had the same crankcase, crankshaft and P/S set.
The 353 and Flash .12 had different cranks which led me to believe they had different timings, but seeing that the newer PT version has the same parts as the previous model just makes me think the Flash series really just got a lightening and newer look to it!
Im really sure it was the Flash engines I was looking at, if not, then just ignore this slab of text
DJ_Shakespear is offline
Old 08-25-2011 | 05:17 AM
  #4132
if the flash .12 3t and the flash .12 pt have the same crankcase, Crankshaft and P/S set doesn't this mean they are pretty much the same engine?
TomB is offline
Old 08-25-2011 | 05:36 AM
  #4133
I can not tell, all I know is that NR is continous changing timings but for some small changes it can be just some tolerances. From what I have seen with other models is that the cranktiming is changed in the crankcase while all the parts in the manual are the same. It is hard to tell.....
Does the new .12 PT and PT have the same black coating on the piston as the larger Flash .21 PT/PTS ?
That can make a huge difference between the 353 / Flash 3T compared with the Flash PT
Roelof is offline
Old 08-25-2011 | 05:49 AM
  #4134
from the pictures on the nova site, no it doesn't seem to have the black coating here are the pics:
.12flash PST
flash .21 PTS
TomB is offline
Old 08-25-2011 | 08:00 AM
  #4135
FLASH.12 AND .12 PT HAD DIFFERENCE CRANKSHAFT,PT WITH BALANCED CRANKSHAFT BUT FLASH.12 NOT,TIMING ALSO DIFFERENCE.PERFORMANCE PT ARE MUCH MORE BETTER THAN FLASH IN OVERALL,BUT FUEL CONSUMPTION FLASH.12 IS BETTER.
kyosho malaysia is offline
Old 08-26-2011 | 04:30 AM
  #4136
According to the exploded views of the Flash 12-3 Tuned and Flash 12-PT, the 12-3 Tuned P/S set is 08627/10 and the 12-PT is 08627/11 (only ONE number!!), so perhaps there is a slight change in port shape or timing making them different, and the cranks are different to each other according to the part numbers.
Maybe it was the RB Touring .12 engines I was comparing that had the same cranks and P/S sets, pretty sure that's what I was referring to in my previous post
Old 08-29-2011 | 05:26 PM
  #4137
12pt's exhaust timing and shape are different - higher, crank duration is (a bit) less, less silicone filling than before, and it's balanced and thus obviously heavier. no coating in the piston. same dome/piston than the older engines
maxflo777 is offline
Old 09-06-2011 | 12:59 PM
  #4138
Riketsu's Avatar
Hey guys,
I am looking for a .12 Novarossi Flash crankcase.
Mine broke at the exhaust with a nasty hit.
Thanks.
Riketsu is offline
Old 09-06-2011 | 07:28 PM
  #4139
Default 35+21 Pipe/Manifold Combi
Hi,
Recently purchased and run-in a 35+21 (steel bearings).
Currently matching it with nova 2015 + 6-fin manifold.
Power is decent at best, but run time is approximately only 4 minutes.
Does anyone have any recommendation for pipe/manifold combination for a large track that offers decent run time (say approximately 4:45?)
Thank you in advance.
Sam
sammies is offline
Old 09-06-2011 | 10:27 PM
  #4140
If you can run the 2013 Sirio pipe it is possible to get 5:30 on a tank.
Roelof is offline
