Airtronics M11X
#1261
I turned my ARC all the way down. I moved the point to 0 which is neutral. So will it adjust the entire band of movement now?
I noticed if you move the point in ARC to say 50%. Then from neutral to 50% of turning the wheel nothing happens. Then when you hit the 50% mark your servo starts to move. Why would anyone want to do that?
Thats why I turned my down as low as it would go and moved the point to 0.
#1262
:Sprikler:
That's pretty funny man (I can see how it could be easy to miss coz you change the expo setting & wouldn't think you have to hit "ok" after doing it, just change menu & it's active), but didn't you think something strange was goin on when you changed your expo settings but they made absolutely no difference?
All the same, glad you got it working now or still no change?
All the same, glad you got it working now or still no change?Aaron, I have not driven it yet since I made the change. We will see this weekend.
#1263
Hi guys
I have had a strange problem with my RX451 today
the car was shutting down randomly on the track and i thought the speedo was at fault because if i switched the car off then on again it was ok , but i noticed the blue BIND light was still on , then the last time it shot off the track at full throttle and shut down , it seams to be the RX451 has stopped working , swapped it with my spare and it is perfect again
I have no blue light now and the reciever doesnt power up , tried re binding but nothing , Anyone had this problem before or can help me fix it ??
#1264
Hello guys. need your help regarding my M11x it won't turn on. traced the F1 fuse but it's good. any more DIY suggestions before i finally send it to Sanwa?
Any suggestions would be greatly appreciated.
Mabuhay from the Philippines!
#1265
Are you running lipo ?? is the lipo ok ??
Are you running AA batterys ??? are they all contacting the springs/contact points , i have some rechargable batterys and the + point is too short and it wont contact on the battery pack , easy check remove the battery set and check the voltage at the connector
other than that i have no ideas Sorry
#1271
Hi, Im thinking about an up grade to my transmitter in my car, and the M11X is on top of my list, I have a MX-3X now (hey, you have to start somewhere right?)
How does this one compare to the likes of Futabas 4FPKS and the Ko Propo 10 Euros?
IŽdont know much about these things and IŽm new to the whole RC-racing, but loving every thing about it (even cleaning the car, TD Desc410R).
#1272
#1273
I have seen wheels whether there what your looking for.
http://www.rc-mushroom.com/product_i...ducts_id=22194
also these which i found they look pretty cool
hope it helps
http://www.rc-mushroom.com/product_i...ducts_id=20721
hope it helps
#1275
I absolutely can't stand the wierd, jagged appearance of the KO, so without even considering its functions, that radio is out for me. 4PKS I also don't like but that's more to do with the layout & use of the Tx coz I much prefer the LCD to be in a 'normal' position, above the steering wheel. I don't like having it on the back there like the 4PKS does.
One feature of the M11x which as yet still no other brand can better is the response time/input lag. The M11x is nearly twice as fast as the 4PK (not sure about 4PKS though), 7.7ms vs 4.0ms average response time & still a little bit faster than the DX3R, 4.7ms vs 4.0ms. I'm not saying I can feel the difference but it's always better to have it & not need it than to need it & not have it.
