Like Tree5Likes
SC10 4x4 Thread
Old 08-22-2011 | 07:45 AM
  #6691
symmetricon's Avatar
Originally Posted by beyondthepack
Ok. If this ha been discust earlier I apologize. But let's say that you have already installed the light weight Ti turnbuckles, and screw kit. Can't you take the made up weight and add it to the front of the truck to off set the battery weight. Without making it as heavy as a tank?
I wass thinking about doing the same thing, but adding the weight to the center chassis, and running a pair of 1s pan style batteries in series, like jamie did in the 4x4 saddle pack thread.
symmetricon is offline
Old 08-22-2011 | 07:47 AM
  #6692
pakk's Avatar
Default saddle packs
If the goal of saddle packs is to balance the truck, and people are adding weight to make the truck more stable, why not just add weight to the original stick configuration till you are balanced at the desired weight.
pakk is offline
Old 08-22-2011 | 07:54 AM
  #6693
Artikbot's Avatar
You got a point!
Maybe adding the ballasts in one side instead of splitting them on both solves the need to use saddle packs.
Artikbot is offline
Old 08-22-2011 | 08:19 AM
  #6694
BlackLabelVinyl's Avatar
That's what I did, and the truck is well balanced and planted.
BlackLabelVinyl is offline
Old 08-22-2011 | 08:31 AM
  #6695
Cameron Kellogg's Avatar
I use stick packs and added weight to ballance the chassis. I have not been able to use a set of scales yet to change the front to back ballance but the left to right is good.
Cameron Kellogg is offline
  #6696
jamie ferrell's Avatar
Originally Posted by rednck21
AnyOne have a source for some 1/4" carbon rod? The one I made out of threaded rod was bent. Just goes to show how much chassis flex this truck has....
mcmaster carr
jamie ferrell is offline
Old 08-22-2011 | 08:36 AM
  #6697
pakk's Avatar
what are you guys finding to be a good total weight? And are you also balancing the wieght f/r?
pakk is offline
Old 08-22-2011 | 08:43 AM
  #6698
Add 6-7 oz and you will love it.
Old 08-22-2011 | 09:02 AM
  #6699
So I ran into a few really fast scts at the track, they all sounded like 1/8 scale on 3-4S. I didn't go peek on their setup but assuming 3s sounds much louder when compared to 2s. correct assumption? (or am I making an azz? )
GuiltyByAssoc is offline
Old 08-22-2011 | 09:08 AM
  #6700
1Fastpede's Avatar
550 motors on a center diff car can sound like 3 or 4 s.
1Fastpede is offline
Old 08-22-2011 | 09:11 AM
  #6701
^^ahh...they were all Losi's...wow do I need that clutch basket bad!
Forgot that my paypal only had $7.00 left so waiting for the bank to transfer the fund.
Old 08-22-2011 | 09:37 AM
  #6702
Depends on how much your battery weighs.
Old 08-22-2011 | 09:45 AM
  #6703
pakk's Avatar
Why would that matter? I'm asking for total weight.
pakk is offline
Old 08-22-2011 | 09:58 AM
  #6704
JayL's Avatar
Guys when tuning this truck WAIT until you can buy the jconcepts Hazard wheels( +3mm offset) it REALLY plants the truck.
or run blitz offset wheels they add +2mm per side and lowered my lap times .5-.7
JayL is offline
Old 08-22-2011 | 10:23 AM
  #6705
I knew the blitz wheels were in legal width. I guess time to test it some more lol
derbrylac is offline
