RC10B4.1 FT/WC
#5266
It's a 5000 mah 40c, ~290g. So I'll call that average. Not sure how it compares to some of the newer higher C lipos.
#5267
#5271
i also used to run about 3/8" rebound with nimh, now with lipo, 3-4mm lol.
http://www.youtube.com/watch?v=sliCx...layer_embedded
tc shocks but the same idea.
#5272
Ι had the same problem and i used the truck or older b4 spring retainers (ASC6475). They are flat and not like a cup as the b4.1's are. That way i got my ride height to even 23mm with silver springs on the rear.
#5273
The 12mm buggy front hex wheels are common with RB5. You can use the truck length axles but they are longer and might require a shim on the outside of the wheel if the nut doesn't tighten completely.
The Losi 22 didn't use a common front wheel with any other manufacturer. You can ask them why....I don't know.
#5274
cut some channels in some 1"x1" stock i had, and put a piece of carbon fiber strip i got from tower to cut them down to 40mm strips for bracing for the chassis.
got my 4 braces ready for my chassis....see how the chassis turn out, maybe end up doing a few for locals lol
#5275
#5277
To be honest, No, IMO..the clear AE cover is about as good as you're gonna get. You could try a light film of grease where it hits the motor plate..
#5278
If anyone you know is looking for a b4.1 or parts, tires, etc...
Please check out my thread.
http://www.rctech.net/forum/r-c-item...ml#post9548914
Thanks!
Carey
Thanks!
Carey
#5279
Need some expert advice on my B4.1 buggy. I finally got it set with great initial steering. The problem is that it washes out extremely quickly. I don't want to loose the initial steering that I have but I want to keep my steering more consistent through the turn without washing out. What should I look at to adjust? I notice this most with off power steering. Thanks for any help you can give me.
