Like Tree5Likes
SC10 4x4 Thread
Old 08-14-2011 | 02:03 PM
  #6211
Originally Posted by Jstall7543
I just read proline makes their tires in the USA, there's one company. I think Panther maybe too.
Yup, panther and proline are too legit to quit.
Krio is offline
Old 08-14-2011 | 02:55 PM
  #6212
Originally Posted by MarqueeRc
Well, I just got back from home depot and purchased a similar looking puncher (only its red)...I tried it a few times on other tires..It works good, but when i punched a tire mounted on a wheel, it does go through the foam??Will this alter the integrity of the foams? The hole goes through the foam small and precise..Will this caus any issues??If i have the wheel off the tire it is a clean cut through the tire and does not effect the foam..The tire i need to punch are mounted?? I know i can make an incision of ther bead but would rather not..Will the foams be ok?
I did..Just stuck my nose to it...I think the hole punching, drilling methods are better though bc you can make a more precise hole and you wont burn the foams which could be worst than having a small incision hole going through them..Trully though, I don't know for sure which is worst?
That seems like a cool way to get er done..So just use those small nail scissors that come in grooming kits right?
Yea, you can make a nice hole with them. Like a paper snowflake the kids make in school. :}
Lon_L is offline
Old 08-14-2011 | 03:03 PM
  #6213
Originally Posted by Artikbot
Guys, what ya think about running a Savox 1251 on this truck?
I can get one BNIB for real cheap (30% off retail price), the new ones with camo sprayed heatsink.
I'm not rough by any means, but the servo will work pretty hard, as the track has continuous subsequent turns.
I burnt down a Bluebird after 15 packs; I want this one to last at least a season (that is around a hundred packs).
I know it's made for touring, but will it work?
Thanks!
Yes it will. I use it in my SCTE. I am suprised it has lasted actually, but it has been fine, and lite
Lon_L is offline
Old 08-14-2011 | 03:10 PM
  #6214
Artikbot's Avatar
Thanks! Just been ordered
Should be here by thursday... can't wait to put this sucker on the track again!
Artikbot is offline
Old 08-14-2011 | 03:11 PM
  #6215
bhambrent's Avatar
Hazard SC10/SC104X4-12 Hex Wheel.
http://www.youtube.com/watch?feature...&v=1A7EaA2Ggls
bhambrent is offline
Old 08-14-2011 | 03:30 PM
  #6216
mrjeremyaaron's Avatar
Originally Posted by bhambrent
THIS IS OFF TOPIC, but... bhambrent, love your avatar image. i could watch that 2 sec loop for hours. endless hours. oh the fun...
mrjeremyaaron is offline
Old 08-14-2011 | 03:54 PM
  #6217
bhambrent's Avatar
Thumbs up
LOL
Old 08-14-2011 | 03:57 PM
  #6218
Having trunks with the shock cartridge if I tighten all the way the shocks bind if I loosen a little the rear shocks do not rebound at all anyone else have a problem with the shock cartridge and is there any solution
SHAUN GRIDER is offline
Old 08-14-2011 | 04:09 PM
  #6219
CraigMBA's Avatar
Remove the upper X ring, OR buy the trackstar.com O-rings, OR buy the trackstar.com O-rings and install one instead of two.
CraigMBA is offline
Old 08-14-2011 | 04:28 PM
  #6220
time for me to chime in about wheel venting.
i cut 4-6 little 'x's around the tire instead of punching holes. depending on some treads, i do 'U's instead. the cuts have no spreaded into a ripping problem at all. tires vent fine and have no dirt. i like this more than the holes since they dont scoop dirt in at all (doesnt matter since the dirt is gonna get shot out anyways), but hey, we're all entitles to preference.
and yes, any holes in the rim are taped and epoxied.
shadoflame is offline
Old 08-14-2011 | 05:01 PM
  #6221
offtraxx's Avatar
just finished our local big race of the year. tq'd and ran 2cd all thru the main.
1:30 left in the race, the fricken wheel fell off again
4 wheels came loose or stripped this weekend between me and my son. I'm running alu hex's and he's still stock with protrack wheels. just ticked me off.
we run a mix of trx and stock nuts(lhs is 1 hr away and not worth the gas to get more) now I'm told hpi nuts are the way to go.
done ranting, still finished 4th and my son got 3rd
offtraxx is offline
Old 08-14-2011 | 05:33 PM
  #6222
1Fastpede's Avatar
I'm still using the kit nuts.
1Fastpede is offline
Old 08-14-2011 | 05:34 PM
  #6223
CraigMBA's Avatar
I've not lost a wheel with the serrated nuts. And I feel your pain on no LHS, except the LHS I do have a forty five minute drive one way has nothing to buy that I need (not even paint), except they did have these axle nuts. Yay Traxxis.
If they are serrated, they are all pretty much the same so long as they are serrated.
CraigMBA is offline
Old 08-14-2011 | 06:08 PM
  #6224
Im still having some issues with the rear end coming around on me sometimes even in the straightaways it gets a bit wild. Im running 2.0 sways f/r, yellow springs front, blue rear springs. 30 wt front 25/rear. 5mm washers under front camber links, 7k weight diffs f/r 3/2 hingpin carrier in rear. Any reccomendations? It just gets squirly in the straightaways with a medium/high bite indoor clay track.
barry1me is offline
Old 08-14-2011 | 06:17 PM
  #6225
jsamarin's Avatar
I believe when you run the protrack wheels, the nylock on the wheel nut dosent actually thread onto the wheel stud, which would explain your problem.
jsamarin is offline
