Like Tree5Likes
SC10 4x4 Thread
Old 07-31-2011 | 07:56 PM
  #5536
symmetricon's Avatar
Thanks for the pics Brandon.
Hey Salad is that a 550 motor, and is it sensored? Come to think of it, that would be insane.
Ive been stuck in MN seeing the family, and is literaly nowhere to race in minneapolis. Cant wait to get back to houston and race
symmetricon is offline
Old 07-31-2011 | 08:04 PM
  #5537
Arigato's Avatar
Can someone who has gone with gearings clutch basket please post pictures on how you "stretched" the cover? I just ordered one and don't want to mess things up.
Arigato is offline
  #5538
all this talk with slipper pads got me thinking....so I went to check out my pads and sure enough they are a bit glased over. I changed both out to the HT pads and cranked down the spring. I wasnt having any issue before so we will see how it does now. I also switched from a 16 pinion to a 14 pinion.
barry1me is offline
Old 07-31-2011 | 08:09 PM
  #5539
I just used a dremel to sand down the inside of the cover. It worked but made the cover quite thin and in one spot i accidentally cut a slit all the way through. Check his thread in the for sale section to see what others have done.
Keeferton is offline
Old 07-31-2011 | 08:17 PM
  #5540
No prob.
Brandon Powell is offline
Old 07-31-2011 | 09:10 PM
  #5541
BLbound's Avatar
Has anyone replaced the stock o-rings in the shock cartridges yet? I wanted to ask how do you open up the cartridge? I bought the o-rings from track star. Thanks for any help!
BLbound is offline
Old 07-31-2011 | 09:40 PM
  #5542
lodhammerdin's Avatar
I have heard of people using a heat gun and a motor can. Heat up the plastic cove and then push it down against the end of the motor can.
I have to say, try fitting the cover on first. I did not have to modify mine at all and I have no rub. I thought at first that I had installed it wrong, so I took it all back apart and re-did everything and same result.
lodhammerdin is offline
Old 07-31-2011 | 10:33 PM
  #5543
Arigato's Avatar
Good to know...Thanks!
Arigato is offline
Old 08-01-2011 | 01:23 AM
  #5544
Originally Posted by Jstall7543
It sounds like its not put together correctly. Maybe buy a new spring, you shouldn't need to have it all the way tight. Mine is like 2 turns tighter than what the book shows and will wheely sometimes on indoor clay with the 3800 4pole. Maybe you have a old kit with thin washers.
Mine is from the first batch from Tower... I am using two thin shims (total of 0.2 mm) after the slipper thrust washer. I have not measured the thrust spacer but I use the shims just in case.
My local track is a combination of dirt, some parts loose some parts hard packed and it also has sections with astro turf. So the driving surface varies around the track. I do also run the Castle 3800. I have not been anywhere near to do a wheely on the astro turf (high bite)...
macke is offline
Old 08-01-2011 | 01:33 AM
  #5545
SaladFork's Avatar
It's a 540, 4200kv, 18.2mm rotor, not sensored.
SaladFork is offline
Old 08-01-2011 | 04:44 AM
  #5546
Default Clutch Basket - "stretch"
Arigato, Buddy of mine did ours. He used a vise and 2 sockets, First socket he used was about the size of the basket. Placed on the inside and a larger one on the other side. closed up the vise and made a perfect stretch and indent. Looks great, take a look
bcinntx is offline
Old 08-01-2011 | 06:10 AM
  #5547
scottmen's Avatar
I replaced the o-rings with the track star ones. Just take the shock cartridge cap off the cartridge body and pull the tube out and the o-rings will be right there.
scottmen is offline
Old 08-01-2011 | 07:46 AM
  #5548
Racecrafter's Avatar
Originally Posted by photobrat
Anybody know if any of the AKA premounts have the correct offset for the SC10 4x4???
No not yet. They will be releasing a new wheel soon that will fit the SC10 4x4.
Your only solid choice for now is stock and DE Racing.
Racecrafter is offline
Old 08-01-2011 | 07:57 AM
  #5549
Numburn's Avatar
Don't like the JConcepts wheels?
Numburn is offline
Old 08-01-2011 | 08:12 AM
  #5550
yup....running the Rulux at the track, love them
evilllempire is offline
