SC10 4x4 Thread
Thinking about getting my first saddle lipo. Track Power 5400 60c. I would like some feed back on the quality of track power and if it's good for my rx8 / pro 4. For the guys with this truck and that lipo. Thanks merry xmas
I need to put thread lock on the shock screws. Would it be a good idea to try to do that with the oil still in them? I'm thinking that's probably not wise. In that case I will chuck the stock oil and do 30/25 for a base setup.
I'm probably just going to drain them anyways and put 5000 front and rear.
Mine had 2 of the 4 loose.
Thought I'd post up some race results, all SC104's and 1 losi. Only one SC104 w/ garodiscs and 2 stage pistons though.
I've given them all fair warning, they know what parts I use, they still don't see the light. Even after months of whoopn's. Some people will never learn..... Closest dude to me is a full 17 seconds back....
Once the RCSHOX center diff comes in, I'll put another lap on them...2011 JCONCEPTS WINTER SHOOTOUT
Pro 4wd SCT open A Main Round# 3, Race# 7
________________________Driver___Car#____Laps____R aceTime____Fast Lap___Behind_
marc moody #1 18 5:07.960 16.215
travis baldwin #2 17 5:06.971 16.595
gary vanlanker #5 17 5:16.799 17.287 9.828
chad winfrey #3 17 5:16.869 16.538 9.898
jeremy feiss #4 17 5:17.496 16.689 10.525
james flagg #7 16 5:07.168 17.161
craig stoeltzing #8 14 5:20.853 18.456
chet ford #6 8 2:52.349 17.811
Scoring Software by www.RCScoringPro.com 11:04:47 PM 12/21/2011
yea I wish I had blue locktited mine , my shock came apart while practicng before my main. I was able to throw back together in like 2 min and in enough time to start the main.
take the time to do it or you'll do it later.
The RTR: (75% will have bought for fun trucks, not race trucks. Kits are bought by racers: Generic Statement) - Will have taken some of that kit problem into account to make it easier for people who AE knows just wants it to 'work'. /LHSEmployee
AE listens. (even if it takes 6 months) Hundreds of people had their shocks fall apart.
What about the diffs? Think the RTRs will be dry too?
It's kind of your guys' call on the shocks. Unless Chris gives us a real AE word.
I just installed a new Tekin RX8, and the fan was working, so I then plugged in the Hotwire, to check out all the adjustments on the PC, then when I plugged the battery in and turned on the ESC, I noticed the fan is not working now. Everything is brand new. What could cause the fan not to work? Or is it supposed to only come on when the ESC reach a certain temp.?
Also for the chassis brace, are you guys using carbon fiber tubing or aluminum? also how exactly are the rod ends connected to the brace? is there a set screw inside the rod end and into the tubing? What size parts are you guys using?
5Likes
