Like Tree5Likes
SC10 4x4 Thread
Old 07-18-2011 | 05:43 AM
  #4786
turbowop's Avatar
umm failing
turbowop is offline
Old 07-18-2011 | 06:26 AM
  #4787
BlueGlowBoy's Avatar
Originally Posted by MadKam
Can you use the same sway bars that fit the slash?
Nope....ex-wife has a Slash 4x4. The bars are substantially different.
BlueGlowBoy is offline
Old 07-18-2011 | 06:34 AM
  #4788
FRONTI3R's Avatar
Originally Posted by JEFFs SC10
I'm having belt problems big time. Belt is slipping and at times it will get bound up in the front. I have the tensioners set for max tension. This is really frustrating.
Mine started to do that this weekend too. Belt was half off on the front.
I pin pointed the issue to the bearing on the front belt tensioner cam adjuster (Bearing 4x8x3mm #31402). It looks like the bearing is worn and therefore the pulley can lean side to side and let the belt fall off from using the brakes.
I'm going to replace the bearing and see if that fixes it... for now all I did is make sure it's tight and put a bit of black greace on the bearing... it worked for another two packs till the end... it started to pull off again because the truck didn't want to move... I put it in reverse and it poped the belt back in to place I believe, I continued to drive it.
Deff. going to replace that bearing this week.
FRONTI3R is offline
Old 07-18-2011 | 07:24 AM
  #4789
you may want to check the actual tensioner hardware as well. On mine, the post was weak enough that when i wrenched on it friday, the post broke right off. i am guessing, my gorilla tightening did it in. maybe the continuous taking apart etc after night of racing, caused the post to bend/crack.
bcinntx is offline
Old 07-18-2011 | 07:42 AM
  #4790
1Fastpede's Avatar
its because your so fast.
Billy "fast lap" Castro
1Fastpede is offline
Old 07-18-2011 | 07:45 AM
  #4791
Matt Howard's Avatar
wish I could do those 19 second laps
Matt Howard is offline
Old 07-18-2011 | 07:49 AM
  #4792
kjohnsiii's Avatar
I am in the same boat except I did not put as much into my losi. Just keep it for an outdoor rig.
Originally Posted by Jstall7543
I ran 4 more packs thru mine today, couldn't be happier! This thing is amazing on indoor! I was holding off 2wd buggies that were running 15/16 sec lap times, they were impressed and so was I. My fully modified losi felt like a pile after running this. I'm in love! Not sure what to do with the losi now lol, put about $300 worth of mods on it, wondering why now.
kjohnsiii is offline
Old 07-18-2011 | 07:54 AM
  #4793
umm winning's Avatar
Originally Posted by symmetricon
The spur gear and the pinion gear must be the same pitch
i feel RETARTED now lol
umm winning is offline
Old 07-18-2011 | 07:56 AM
  #4794
CentralCoaster's Avatar
started with the softest sway bars.... front keeps coming loose at ends even with locktite.
Anyone had this issue?
I don't like what its done to truck in jump section... if you aren't perfectly lined up it really tosses you.
Definitely helped with the high speed sweepers though.
CentralCoaster is offline
Old 07-18-2011 | 08:00 AM
  #4795
bcinntx is offline
Old 07-18-2011 | 08:01 AM
  #4796
LouDawg's Avatar
ATTN: For those of you having issues with your slipper and rear end slipping
All you need are a couple of 1/4" washers between the slipper nut and spring, and one AE high torque slipper pad.
This is all i did and i fixed my slipping and poor acceleration issues. Heres a video of it tightened down.
+ YouTube Video
I can finaly tune my rear end for the track!!
4wd SC10 wheelies are possible!!
LouDawg is offline
Old 07-18-2011 | 08:29 AM
  #4797
Default 4s battery and motor setup?
I've noticed people modifying the sc10 4x4 battery mounts to allow for a saddle pack config which got me to thinking... what about changing it up to allow a a couple of 2s packs to fit in there? Probably need to create a platform to put the electronics on so you could could put the batteries side by side on the bottom of the chassis but it could work.
Be nice to get the added run time 2 packs would offer if you hooked them up in parallel, but imagine if you hooked them up in series. You could run an rx 8, but would a Tekin T8 fit in there? Hmmm...
Yes you would need to dial the power back to a manageable level and no it wouldn't be ROAR legal... but man it would fly.
Anybody tried it?
Redbeard is offline
Old 07-18-2011 | 08:43 AM
  #4798
murky123's Avatar
2s parallel would double the runtime, would probably double the heat in crucial components
murky123 is offline
Old 07-18-2011 | 09:27 AM
  #4799
Robotech's Avatar
So I raced my truck this weekend and came to one conclusion...
...I need to practice a LOT.
This whole "jumping into the air" thing is really throwing me for a loop. So use to on road that I got thinking too much about jumping and completly forgot how to drive a 4wd car into a corner. Once I started getting that straightened out I did much better except for a jump on the back straight that I kept lining up wrong and landing in the weeds...every lap...
So, with that disclaimer posted, I tried the truck with the box stock setup and I didn't like it so I threw on the 2.0 swaybars and upped the front diff fluid to 30K from 5K...which, might I add, trying to do between heats is NOT easy when all you have is hand tools. Someone let me borrow their power driver after they saw the time I was having taking it apart and I got it done about 5 seconds before my race was to start. Mental note, need one of those things.
We went down to a "C" main and I was 12th there...finished 8th but only 9 cars running so yea, I need to practice. Even so, I was only (ha ha...ONLY) a lap behind first and on the same lap as 2-7. So I figure I'm going to leave the truck alone for now...maybe swap the rear sway out for a 1.5...and work on my driving skills.
I did notice that the truck likes throttle. It works much better as long as you're giving it some gas through the turns...it works much better that way. So if I can get over this "Jump-phobea" of mine the way I drive touring cars should help out some. Oh, and I need a new body...black does not do well at night on a poorly lit backstraight...yea...
Robotech is offline
Old 07-18-2011 | 09:53 AM
  #4800
OSherman's Avatar
Thumbs up
Originally Posted by Robotech
....So if I can get over this "Jump-phobea" of mine the way I drive touring cars should help out some. ..yea...
i can relate to that..
OSherman is offline
