SC10 4x4 Thread
#5536
Thanks for the pics Brandon.
Hey Salad is that a 550 motor, and is it sensored? Come to think of it, that would be insane.
Ive been stuck in MN seeing the family, and is literaly nowhere to race in minneapolis. Cant wait to get back to houston and race
#5538
all this talk with slipper pads got me thinking....so I went to check out my pads and sure enough they are a bit glased over. I changed both out to the HT pads and cranked down the spring. I wasnt having any issue before so we will see how it does now. I also switched from a 16 pinion to a 14 pinion.
#5540
#5542
I have to say, try fitting the cover on first. I did not have to modify mine at all and I have no rub. I thought at first that I had installed it wrong, so I took it all back apart and re-did everything and same result.
#5543
I have heard of people using a heat gun and a motor can. Heat up the plastic cove and then push it down against the end of the motor can.
#5544
It sounds like its not put together correctly. Maybe buy a new spring, you shouldn't need to have it all the way tight. Mine is like 2 turns tighter than what the book shows and will wheely sometimes on indoor clay with the 3800 4pole. Maybe you have a old kit with thin washers.
My local track is a combination of dirt, some parts loose some parts hard packed and it also has sections with astro turf. So the driving surface varies around the track. I do also run the Castle 3800. I have not been anywhere near to do a wheely on the astro turf (high bite)...
#5545
#5546
Arigato, Buddy of mine did ours. He used a vise and 2 sockets, First socket he used was about the size of the basket. Placed on the inside and a larger one on the other side. closed up the vise and made a perfect stretch and indent. Looks great, take a look
#5547
I replaced the o-rings with the track star ones. Just take the shock cartridge cap off the cartridge body and pull the tube out and the o-rings will be right there.
#5548
#5549
5Likes
