Like Tree5Likes
SC10 4x4 Thread
Old 07-24-2011 | 11:59 PM
  #5131
Wild Cherry's Avatar
Don't chea love when somebodies buddy said his
losi is so good and whatever ?
cheeees ....
The Sc10 is very competitive out of box ....
Brand new & only gona get faster & faster .....
Wild Cherry is offline
Old 07-25-2011 | 01:29 AM
  #5132
murky123's Avatar
underbody. just needs a little paint.
keeping my brand new Xerun 120A V2.1 speedo clean and dry.
good thing is that the motor is outside the underbody, so no theat from that component trapped under the body
murky123 is offline
Old 07-25-2011 | 05:32 AM
  #5133
dirtydan's Avatar
who makes that cover?
dirtydan is offline
Old 07-25-2011 | 05:43 AM
  #5134
dirtydan's Avatar
hey guys i just ordered my sc10 4x4 on thurday and should get it mid week. this is my first electric truck since i was 13 lol. i ordered the f/r swaybars, 30k diff oil for the front diff, 5k for the rear diff. im planning on using 32.5 weight in the front and 25w in the rear. also i ordered a mama monster esc and a castle 1410 3800kv motor. for steering i went with the savox 1257 servo. now i also ordered a 14t 32pitch pinion. do you guys think this setup will work well? i got the mamaba monster esc because it was on easy pay, and the mmp was out of stock. do i need to use a glitch buster or bec with this setup? im using a futaba 4pks system.
thanks,
Dan
dirtydan is offline
Old 07-25-2011 | 06:12 AM
  #5135
That is associated's overbody. I was impressed when
mine showed up with the vents and leaving the motor uncovered while providing some protection.
Krio is offline
Old 07-25-2011 | 06:41 AM
  #5136
symmetricon's Avatar
thanks,
Dan
Your setup sounds rock solid, although i would go up to a 15t or 16t pinion.
symmetricon is offline
Old 07-25-2011 | 07:35 AM
  #5137
32 pitch?
shadoflame is offline
Old 07-25-2011 | 07:45 AM
  #5138
offtraxx's Avatar
I got a friend running that exact setup. he's got a 12 tooth pinion and can pull away from my 6.5 geared 13/60 on the short straights. long straights, I can catch him, but not to many of those at our track.
u should be good with the 14 for sure.
offtraxx is offline
Old 07-25-2011 | 08:12 AM
  #5139
Rick Hohwart's Avatar
Originally Posted by racer1812
I'm just about as AE as you can get BUT if you're the guy who wants to put a truck together and just drive it, this truck MIGHT not be for you. The Losi owners I race with all say that the Losi is simple stupid and good right out of the box. The AE truck IMO isn't, you really need to have some set-up knowledge and be willing to put in the time to find a set-up that works on your track. If you can do that then this truck can be as good or better than the others. If not, then it won't be and you will be disappointed...IMO
Plus the truck is still pretty new in the hands of the racers and many of the team drivers. Setups will develop and the truck will get better and better.
When the 2wd SC10 was released, I recall Slash drivers saying that it was too hard to drive and that they were going back to their Slash. Look how that turned out.
Rick Hohwart is offline
Old 07-25-2011 | 08:25 AM
  #5140
Tekin sc4x motor mount screws, which size do you folks use?
4mm seems more secured (but have to buy them)
3mm means have to move the mounting pts on the motor plate?
thx!
GuiltyByAssoc is offline
Old 07-25-2011 | 08:35 AM
  #5141
thx!
On my sc10 and my wifes both with the sc4x motors we are using the included 3 mm screws just fine. Just rotate the end to get the solder tabs pointing where you want them n
Krio is offline
Old 07-25-2011 | 08:45 AM
  #5142
Cain's Avatar
Originally Posted by turbowop
My back wheels pick up a LOT of dirt through those holes, but so far my tires have been okay since I have holes punched through them as well to let the dirt escape. I'm removing dirt from parts of the track and replacing it in others.
Shouldn't holes in the tires take care of the issue with plugging the holes in the rims? Or, do we still need to plug those holes?
Cain is offline
Old 07-25-2011 | 09:16 AM
  #5143
Cool, Thanks!
Old 07-25-2011 | 09:25 AM
  #5144
nmdesertracer's Avatar
by any chance will the b4's ball diff fit in this truck?
nmdesertracer is offline
Old 07-25-2011 | 09:26 AM
  #5145
Like a noob, I didn't center the servo (I know..tsk..tsk). Am I SOL or is there a way to adjust the servo mount without spending a day disassemble the car?
