RC10B4.1 FT/WC
Old 07-21-2011 | 02:02 PM
  #4171
Asharus's Avatar
Originally Posted by JW91
I run just about the same setup at our local track. It's not as springy as a lighter car, but It launches off the corner though better and turns in well.
I'm able to run our track using little or no brake to get the car through the corners.
+1
Plus all I do to run it at an outdoor dirt track is give it a degree of toe out in the front and different tires and it turns with no problem on power.
Asharus is offline
Old 07-21-2011 | 03:28 PM
  #4172
Eli's Avatar
Eli
Originally Posted by TAMAK
I am in the same boat, wish i never sold my FT B4. I am happy with the B4 being what it is. I think after this Ifmar win, associated B4.1 will be in production for another two years.
What I would love to see is a Special Cav / IFMAR edition. .
Associated is pretty clever... They Hire amazing drivers + They win championships= Less research and development on a vehicle that they know is proven.
However, the new Durango car looks SEXY...
Maybe b4.1L or worlds edition or something on those lines.
Eli is offline
Old 07-21-2011 | 10:30 PM
  #4173
AZRC4Me's Avatar
Originally Posted by Jmuck69
Ryan Cavalieri used K springs at the EOS race.
what weights does cav use in the rear triangles? the 1/4oz weights don't really fit well into those rear triangles, and these are obviously different.
http://www.rctech.net/forum/9285669-post3367.html
AZRC4Me is offline
Old 07-21-2011 | 10:36 PM
  #4174
Cpt.America's Avatar
The 1/4 oz weights I use look identical to those.
Cpt.America is offline
Old 07-21-2011 | 10:58 PM
  #4175
AZRC4Me's Avatar
sorry, what I should have said is that the 1/4oz associated weights don't fit very well back there:
http://www.amainhobbies.com/product_...is-Weights-2oz
and those don't look like what cav is using...so what brand does he/you use or where can I find those? thanks.
AZRC4Me is offline
Old 07-21-2011 | 11:09 PM
  #4176
D-Rek07's Avatar
I was looking at some pictures of the Worlds coverage and noticed that Ryan Cavalieri runs a plastic hinge brace. Why is that? I was really excited because that is part the rtr and that is what I have.
D-Rek07 is offline
Old 07-21-2011 | 11:39 PM
  #4177
Matt Trimmings's Avatar
Those are the older style that Associated sold a few years ago, i really dont like the newer ones either. Luckily i was able to scrounge up some of the older ones and treat them like gold. I have not been able to find anything that fits as good as the old ones.
Matt Trimmings is offline
Old 07-21-2011 | 11:48 PM
  #4178
I heard that you are less likely to break an a arm with one of those... but I still run the aluminum (havent broken to many arms lately)
gguertin145 is offline
Old 07-21-2011 | 11:52 PM
  #4179
Wild Cherry's Avatar
plastic brace is use to gain extra steering due to its ability to flex more...
They(Team Drivers) also are trimming the dimple off the ft bulk head & installing a larger screw , not sure what size screw ....
Wild Cherry is offline
Old 07-22-2011 | 12:20 AM
  #4180
Default EXTENDED B-4 CHASSIS MOD
Todays project, took me 2 1/2 hrs including Taco's from the bus ...
What you need to do ...
1 new T-4 Chassis
1 old broken B-4 chassis or T-4 , Sc10
Dremel with a cut off wheel
a set of caliper's
1 piece of 150G sandpaper
Tire glue
1/4 masking tape
1 pro-line bull dog body (it fits)
Directions
#1 find the two find straight lines going across under the middle of chassis ....
lay a strip of 1/4 masking lap on the outside of the most forward line in the middle of chassis ...
measure from the tape towards the rear of the chassis 11.1m & mark
lay a 2nd piece of 1/4 masking tape on the line you just mark...
cut chassis in half in the middle of the two lines of tape with cut-off wheel.
use the cut-off wheel and sandpaper to grind the extra plastic right to the edge of the tape.
cut the straight sides off of old broken chassis to make L braces & glue all together as seen in pictures below
Very strong & stiff , you will not be able to break it by hand even if you try too.....
Chassis will be 8m longer than the standard B-4 chassis as reported being use by the team at Worlds....
Excuse the hack job craftsmanship...
Attached Thumbnails RC10B4.1 FT/WC-extended-b-4-chassis-002.jpg   RC10B4.1 FT/WC-extended-b-4-chassis-003.jpg
Old 07-22-2011 | 12:33 AM
  #4181
Wow...that looks horrible.
Old 07-22-2011 | 12:37 AM
  #4182
beauty is always in the eye of the beholder
car is smoother , more stability in turns & at speed....
Old 07-22-2011 | 12:39 AM
  #4183
I get that...but it looks like a complete hack job. Mine took less than 2 hours and came out loads better. Use enough glue?
Old 07-22-2011 | 12:40 AM
  #4184
lets see it ...
Old 07-22-2011 | 12:41 AM
  #4185
lets see it ...
I would be glad to post a pic tomorrow, im at work right now.
