Like Tree5Likes
SC10 4x4 Thread
Old 07-13-2011 | 09:03 PM
  #4606
symmetricon's Avatar
quick question , is there any difference between the FT cvd's(shiny) and the stock cvds?
symmetricon is offline
Old 07-13-2011 | 09:18 PM
  #4607
Originally Posted by symmetricon
quick question , is there any difference between the FT cvd's(shiny) and the stock cvads?
a dollar for every time this question is asked since ae does shiny dogbones
smellslikenitro is offline
Old 07-13-2011 | 09:21 PM
  #4608
Duhhh, shiney is faster!? Its quite apparent. Nah, i bent the sh*t out of on e and was wondering if there is a reason to buy the FT.
Old 07-13-2011 | 09:24 PM
  #4609
i bent my stock ones as well. any aftermarket ones?
shadoflame is offline
Old 07-13-2011 | 09:39 PM
  #4610
Hope this isn't a repost but rcplanet.com shows they have sc10 4x4's in stock...
Bondobird is offline
Old 07-13-2011 | 10:12 PM
  #4611
JFuel11's Avatar
Default Yellow Front Spring...
Originally Posted by kdub
This is the setup that I worked on with the Wachter brothers Jonny and Clint. After the race was over, we learned some more and made the truck fast and easy to drive but it was too late...we'll get 'em next time.
To get the heavier rate front springs, you can also substitute original bronze RC8 front springs until our springs are available. They are a bit longer so it might not be possible to get 24mm ride height without removing a coil or two.
This setup is close to what I am already running but I need the Yesllow springs badly! Are they for sale anywhere yet?
JFuel11 is offline
Old 07-14-2011 | 01:26 AM
  #4612
racer1812's Avatar
Super Moderator
Are you talking about the pre production yellow springs run by AE drivers before the truck was released? They are the same as the "blue" springs that come on the truck...
racer1812 is offline
Old 07-14-2011 | 02:51 AM
  #4613
jpure009's Avatar
So a while ago I mentioned something about dual stage pistns, well they will be availible soon, I have been helping test them out and the freakin rock. On a rough track they help out a ton in the rebound rate, equaling greater tracktion. Check em out at rcshox.com
http://rcshox.com/
Nothing???
jpure009 is offline
Old 07-14-2011 | 03:43 AM
  #4614
I need some help here. Last night I drove at my local track (large 1/8 track). The car performed really good overall but... on the largest jump I always got some severe nose diving. The jump must be taken at a high speed and I was almost forced to hold full throttle in the air (from jump to landing) to not land on the nose. I'm having 35/30 AE oil in the shocks and lengthened the shock by two turns. What is the solution to avoid the nose dive? Put heavier oil in the rear? Any suggestions are greatly appreciated.
macke is offline
Old 07-14-2011 | 05:03 AM
  #4615
sparkwraps's Avatar
Stand up the front shocks. That should fix the big jump, tune for everything else on the track.
sparkwraps is offline
Old 07-14-2011 | 05:08 AM
  #4616
I had this same issue and it was due to having to much drag brake set on my RX8 esc.
isarctard is offline
Old 07-14-2011 | 05:11 AM
  #4617
Originally Posted by jpure009
comming soon.....
Old 07-14-2011 | 05:12 AM
  #4618
JFuel11's Avatar
Default Nope, yellow 4.8 rate spring...
The setup recenlty posted has listed the use of a Yellow 4.8 Rate front spring. Was just curious if they have hit the market yet since they are showing up on setup sheets. I am getting frustrated a bit that I don't have all the tools I need to tune this truck more for track conditions. Need some different spring rates.
JFuel11 is offline
Old 07-14-2011 | 06:16 AM
  #4619
upDUHcreek's Avatar
Default Best motor
Ok, I guess I'm getting back into electric RC just to have something I can race at the local track. I am about to order the SC10 4x4, and probablly a Castle 1410 motor. Before I place my order, I just thought I'd ask if the 1410 is going to work for me. I'll be racing on a small indoor track
http://www.youtube.com/watch?v=U5OxTATiSQc
and a very large outdoor track, that's a 5th scale in this video.
http://www.youtube.com/watch?v=M8yAlmouBsU
Is the 1410 going to be enough torque for the small track, while still being fast enough for the big track? I know I'll probablly have to change the gear ratio between the tracks.
Also, I've seen a few speed controls reccomended with this motor, will one of them run cooler than the others? It gets pretty hot around here, and I'll need a speed control that can cope with air temps around 100 degrees.
Thanks in advance for any help, Charlie.
upDUHcreek is offline
Old 07-14-2011 | 06:24 AM
  #4620
Charlie, the 1410 has more than enough power for whatever track you plan on running.I ran min with a hobbywing sc10 esc, which can be bought for 60-70$, and it ran nice and cool(120deg), btw live in Houston so you know its hot here. I recently switched to a MMP with a LRP 5.5T 550 and like it much more, much smoother, just mmy opinion. I like the bottm end smooth , than ad boost around 10000 rpm for some mid-range torque and top speed. but the 1410 is a solid motor.
