Like Tree5Likes
SC10 4x4 Thread
Old 07-13-2011 | 11:53 AM
  #4576
Questions?? ball stud washers ?
I keep reading about traction roll and the use of washers under the ball stud.
I run on a very dry, dusty and slick track and traction roll isn't an issue. Could I still gain any benefits or disadvantages by running washers under the ball studs
isarctard is offline
Old 07-13-2011 | 12:01 PM
  #4577
Troy*Fanciullo*'s Avatar
it wouldnt hurt the truck, it might give it more stability on a "slick" track.
has anybody made homemade sway bars?
Troy*Fanciullo* is offline
  #4578
Matt Howard's Avatar
you'll probably actually want the extra lean from the stock setup in those conditions. The washers under the ballstuds keep the truck from leaning so much by lowering the roll center.
Matt Howard is offline
Old 07-13-2011 | 12:07 PM
  #4579
That's what I was thinking, thanks. This thread could use more input from the guys running on dry loose slick tracks. We don't all get to pleasure of running on clay =[
Old 07-13-2011 | 12:09 PM
  #4580
Originally Posted by Cameron Kellogg
I know not everyone has big sockets in their tool box but...
I took a 1 1/2 socket on the outside of the cover a 1 1/8 on the inside of the cover and ran a long bolt/nut through the the sockets and the center slipper adjusting hole in the cover. I tighten the bolt and it pushes the little socket in to the big one coning the cover out. Put some heat too it with my wifes super hair dryer and then let it cool. Makes a perfect round bulge in the cover for the basket to clear.
Do you have any pics of the cover? I'd like to know what it's supposed to look like. I haven't seen images of the final outcome and if there posted I missed them.
  #4581
Numburn's Avatar
So for maximum grip (and body roll) you would run longest camber links with no spacers correct? I've been running spacers using the inner ball stud mount, but after reading stuff on here it seems I could have accomplished nearly the same thing by running short links with no spacers.
I just got sway bars in and plan on installing them before a big race this weekend. I'm thinking I should remove the spacers and leave the links long to keep some grip.
Numburn is offline
Old 07-13-2011 | 12:10 PM
  #4582
Numburn's Avatar
I'd love to see some pics myself. Thanks for the tip Cameron. I plan to give it a shot tonight.
Numburn is offline
Old 07-13-2011 | 12:41 PM
  #4583
Stripped the servo horn today. 100% sure I used the correct one. 25 spline for a Team Orion servo. Does anyone know if there is an aluminum one that will fit?
Also, what is the quickest way to change the servo horn? It seams that I have to tear down the whole front to get access to it...
macke is offline
Old 07-13-2011 | 12:55 PM
  #4584
now that is an explanation.
So could you raise and lower the front and rears independently to change the way the truck corners or is it recommended to raise the front and rear ballstuds equally?
Keeferton is offline
Old 07-13-2011 | 01:01 PM
  #4585
you can do each end independantly. I'm running 4mm under the front and none under the rear on a watered track. If the track isn't watered it has less traction so I run 2mm under the rear to give the rear a bit more "bite".
Old 07-13-2011 | 01:06 PM
  #4586
Robotech's Avatar
Yes...and no. Maximum body roll does not equal maximum grip.
If you start rolling too much and picking up your inside tire, you just cut your overall contact patch on that end of the truck by half. Not good. It's about balance.
There's kind of four stages of grip. Stage one...not enough weight transfer and the end of the car "washes out" (Push if it's in the front, spin if it's in the rear). Then there is balanced, the end of the car is stable. Then you have slightly too much weight transfer. The inside tires lifts or gets too light, reducing the contact patch, and that end washes out again. This is just shy of the last stage, a traction roll. Too much weight transfers and the vehicle flips over.
You want to find that happy second stage where the end of the truck is stable.
I would leave your setup alone and just add the sway bars and see what it does. Then remove the washers but leave the sway bars on and see what it does. Proper setup can't be suggested...you have to try different things and see how it feels to YOU. Remember, only make ONE change at a time. Removing ball stud washers AND adding swaybars all at once is a big no-no as you don't know how each change affected the truck.
Matt, I'm wondering...if you get more "bite" by reducing roll if the track get's LOOSER (which is kind of opposite...) I wonder if when they water it you would be faster if you ran 6mm under the fronts and 2mm under the rears rather than 4mm front and 0mm rear? It might give you more overall grip and help keep your corner speeds higher?
Just curious if you've tried that and what your results were.
Robotech is offline
Old 07-13-2011 | 01:22 PM
  #4587
Cameron Kellogg's Avatar
I will post some pic's tonight in the clutch basket thread.
Cameron Kellogg is offline
Old 07-13-2011 | 01:25 PM
  #4588
Numburn's Avatar
Thanks for the tips Robo!
There's a clutch basket thread? Got a link handy?
Numburn is offline
Old 07-13-2011 | 01:27 PM
  #4589
http://www.rctech.net/forum/r-c-item...ch-basket.html
Old 07-13-2011 | 01:31 PM
  #4590
Thats really the only way to get to it... ive broke the steering links in a race and fixed it within 15 minutes. .
its all about getting to know the car so every time you get faster and faster putting in back together!
