Like Tree5Likes
SC10 4x4 Thread
Old 07-07-2011 | 03:53 PM
  #4291
symmetricon's Avatar
Tires tires tires makes or breaks this truck. Calibers suck to me. I recently tried AKA enduros in soft compound and it made a huge difference in rear traction.
symmetricon is offline
Old 07-07-2011 | 04:05 PM
  #4292
Cain's Avatar
anyone running same tread design tires but with different compounds front and rear? would like to hear how that has been working for you.
Cain is offline
Old 07-07-2011 | 04:14 PM
  #4293
Farmer_John's Avatar
Outside on sun baked grooved soil, I've had great luck with SS Enduros, all the way around.
Indoors on damp clay, different story. I bought some of the treads that work for me on this track. Ended up with soft HB Beams in back and soft Double Ds in front. If I ran all four matching, I was less than thrilled with the result.
Farmer_John is offline
Old 07-07-2011 | 04:19 PM
  #4294
is anyone having to add weights to balance our their truck? to my luck, the battery side is slightly heavier than the electronics side. im used to it being the other way around. for my 10th scale on-road sedan it was very critical to balance it.
does it apply critically in off road as well?
shadoflame is offline
Old 07-07-2011 | 04:24 PM
  #4295
spunkysandoval's Avatar
does anyone know if the gears from the 4x4 diffs fit into the 2wd sc10?
spunkysandoval is offline
Old 07-07-2011 | 04:37 PM
  #4296
slowtruggy's Avatar
I have been running jconcepts double ds green on front and rear works great for me!
slowtruggy is offline
Old 07-07-2011 | 05:28 PM
  #4297
bronc4now's Avatar
my shocks are butter cant wait to try'em out!
bronc4now is offline
Old 07-07-2011 | 05:38 PM
  #4298
bronc4now's Avatar
i started with barcodes green was ok i guess, now im trying subarbs s.soft ,i have some subcultures that i havnt even tryed yet ..indoor dirt
i have no ideal just trying things ..lol
Old 07-07-2011 | 05:44 PM
  #4299
ilanstylz's Avatar
I run gold barcodes or suburbs for indoor clay track with great success, and I am going to try out aka cityblocks for the outdoor dirt track in my area......
ilanstylz is offline
Old 07-07-2011 | 06:17 PM
  #4300
Default Diffs Leaking around out-drives
I have sent the following to associated support and thought I should probably post it on here also...
If anyone has any ideas please let me know.
Tks
Steve
-------- Original Message --------
Subject: Kit Service SC104x4
Date: Thu, 07 Jul 2011 20:57:09 -0400
Reply-To: [email protected]
Dear Associated Support,
I have two SC104x4's and I seem to be having a problem with the diffs
in both trucks.
One truck has around 10-12 packs thru it and it appeared to be loosing
diff fluid out both diffs thru the out drives. I have disassembled this
truck and found both diffs with VERY little fluid, not dry but little
oil. Because I was warned to check them... they were filled 3 weeks
ago, when I was assembling the trucks. Additionally because this fluid
is contaminating the the bearing and attracting dirt about the bearing,
two of the 4 bearings seem to have grit in them. I do NOT think this
would be a problem is it were not for the diff fluid seeping out and
attracting dirt.
As a further note the out-drives on both diffs seem to be wobbley and
now seem to fit loose into the diffs
I can't tell for sure, but the second truck also seems to be getting a
dirt build up behind the out-drives (I can't tell for sure), with just
4-5 packs thru it..
Additionally I have checked my parts list and "O" rings do not seem to
be available EXCEPT if I buy a whole diff rebuild kit.
I sure hope this is a mistake and the "O" rings are available separately.
I really like these trucks a lot, but at this point I am VERY concerned
about this diff problem.
As you know the truck requires almost a complete tear down to get to the
diffs to service them and to deal with the bearings. It is ridiculous
to think I will have to tear these trucks down after every 10-12 battery
packs for this service.
Again I really like the way this truck handles, and have two of them
running and another in the box....not built.
I sure hope there is a easy solution to this problem.
Thanking you in advance for your time.
R. Steve Haynes
I am going to post this to the SC104x4 list also...maybe some one there
has an idea.
kd4arf is offline
Old 07-07-2011 | 07:35 PM
  #4301
Double d's look to be money, and i really like how jconcepts tires have a bigger contact patch, they will probably be the next tires i try.
Old 07-07-2011 | 07:40 PM
  #4302
Originally Posted by Hyper_Mike
I'm going to chime in here because, up until last night, I kinda felt the same about my SC10 4x4. I was having the same kinds of problems...twitchy, tail-happy handling both on entry and exit...feeling like I needed to tip-toe around every corner. I had been running M4 Calibers all around (and not getting nearly enough traction with them!) when another racer at our track suggested I try running the kit tires up front. I didn't have them with me but I did have some M3 Snipers which I threw on the back and lo-and-behold the truck came to life! I could now throw the truck hard into corners and accelerate out of corners with authority and it even jumped more efficiently with the better rear traction. I literally picked up an extra lap on a large 1/8th scale sized track with the tire change alone !
It may fall into the category of a setup "band-aid" but I really think this truck works better with a less grippy tire up front (or conversely, a grippier tire out back ). For the record, here is my setup:
Front:
30wt Losi oil/stock springs/kit shock positions
20,000wt diff
2.0mm swaybar
Kit camber link positions/3mm under inner ballstud
29mm ride height
M4 Calibers
Rear:
25wt Losi oil/stock springs/kit shock positions
7,000wt diff
no swaybar (don't have mine yet )
Kit camber link positions/2mm under inner ballstud
29mm ride height
M3 Snipers
I would respectfully suggest to folks who are struggling with this truck to throw the kit tires up front to see what it does...it's easy and quick to do and based on my experience it might help!
Cheers,
Mike
good idea i will try it i have tried super soft enduros snipers bowfighters calibers ill try anything now i really like the sc10 just driving me crazy
250r is offline
Old 07-07-2011 | 07:49 PM
  #4303
Eli's Avatar
Eli
Anyone running a 540 set-up try removing some teeth from the belt to lower resistance?
Eli is offline
  #4304
the enduros didnt work well for you?? maybe AKA gridirons. Besides roll center and diff oils, tires have made the biggest difference with the truck for me.
Eli, are you seriouse? no sarcasm intended.
Old 07-07-2011 | 07:58 PM
  #4305
T-BirdJunkie's Avatar
It's an on road thing. ThunderbirdJunkie considered soaking his belt in WD40 or whatever it is the on road guys do to flexibilize their belts when he built his truck...but...he decided nah. No tangible reward in this scenario.
ThunderbirdJunkie is thinking the same thing of the belt, although it may be OK as long as you're not running over/underdrive pullies or landing nose down and wide open (as ThunderbirdJunkie has a tendency to do)
T-BirdJunkie is offline
