Like Tree5Likes
SC10 4x4 Thread
Old 07-03-2011 | 01:22 PM
  #4066
lbckevin's Avatar
Originally Posted by omaha_racing
So I am looking at getting one of these. Everyone at my local track has the Losi, and I want to be different. Has anyone noticed and major wear items yet, and what has a tendency to break first? Also has anyone had a hard time getting a 550 motor to fit in the truck? Also would their be enough room on the electronics tray to make a RX8 fit without any problem? Thanks for the input!!
My Tekin Rx8 speedo fits perfect and I put a 4.5 tekin motor as well.
lbckevin is offline
Old 07-03-2011 | 03:06 PM
  #4067
t4mania's Avatar
Originally Posted by chumanji
If there a wheel hex adapter for this truck to use 1/8th scale tires?
AKA racing makes a great set of 17mm adaptors for buggy tires..
t4mania is offline
Old 07-03-2011 | 03:27 PM
  #4068
T-BirdJunkie's Avatar
Originally Posted by kromesoldier
Someone sent me a pic of an 1/8 castle motor but the chassis was really cut up
I have the 1415 in which is more than enough power and you can still move for pinions
That's good news, because the LRP Vector8 2800kv ThunderbirdJunkie bought for $40 might not be a wasted experiment
T-BirdJunkie is offline
Old 07-03-2011 | 03:32 PM
  #4069
TQ and A-main win the first night out. Turned almost a full lap more than the Jammin' SCRT I was running before. Still a bit more oversteer than I'd like but we'll get there. I'm gonna try spacing up the rear inner ball stud abot 2mm and see what happens. Anybody run the front clicker loose enough that it actually "clicks". What is it suppose to be doing?
qwkpony is offline
Old 07-03-2011 | 03:38 PM
  #4070
Matt Howard's Avatar
I tried a 2mm spacer under my rear ballstud this past weekend and it did plant my rear a little bit more. I already had my truck pretty good so I took it out, if you're looking for a bit more rear traction then it should be the ticket for you. When the clicker is loose enough to "click" it lets the front wheels freewheel like a oneway bearing for the front end. It will give you more steering but takes away your ability to have 4 wheel braking (more likely to spin out under brakes)
Matt Howard is offline
  #4071
If it doesn't click, you've got 4w braking. You can rotate the truck more under braking with the clicker unlocked. It's also a good way to get the attention of an inattentive marshal when you're on your lid.
WEEEEEEEEEEEEEEEEEEEEEEZTZTZTZTZTZTZTZTZTZTZTZTZTZ TZTZTZTZTZTZTTZTZTZTZT
Old 07-03-2011 | 04:18 PM
  #4072
Thank you for the explaination. I'm very familiar with front one-ways from my days of running touring cars. More steering I don't need so I'll leave it alone.
My next changes will be installing the front overdrive pulley and 2mm under the rear inner ball stud. I don't think I'm a smooth enough driver for the overdrive pulley but you never know until you try.
qwkpony is offline
Old 07-03-2011 | 04:39 PM
  #4073
I think either my 2wd SC10 is sabotaging me, or my 4x and I are fighting. By the end of the first run, I could feel the 4x slipper was slipping again, even though I took some drastic measures on it to keep it from happening. Retightened, went to try it again, and the servo (1015) made nothing but death twitches. Tried it in 2 other trucks, it was dead for sure. Ran some packs thru the old faithful 2wd instead, since I didn't want to mess with switching out the servo at the track. I'd rather do it at home with a Pacifico and the AC on... Back to the ol' drawing board...
maddysdaddy is offline
Old 07-03-2011 | 04:47 PM
  #4074
Greg M's Avatar
Has anyone thought about ditching the slipper completely?
Greg M is offline
Old 07-03-2011 | 05:00 PM
  #4075
You'll be tearing up gears and belts really quick that way. Other trucks have a center diff and steel gears and are really heavy because of it.
Old 07-03-2011 | 05:05 PM
  #4076
Greg M's Avatar
Ok, it just sounded like so many people were cranking them up so tight that they wouldn't be doing much, or else having issues with too much slip.
Greg M is offline
Old 07-03-2011 | 05:08 PM
  #4077
slowtruggy's Avatar
i raced mine last weekend at the alabama manufacter shoot (a big track) in alabama then ran it yesterday doing a little practice on a small indoor track in Ohio and im really starting to like the way it drivers!!!!! still dont have sway bars yet so if it drives better with them then i cant wait!
slowtruggy is offline
Old 07-03-2011 | 05:13 PM
  #4078
you need a little bit of slip, just for drivetrain protection.
Old 07-03-2011 | 06:06 PM
  #4079
mrjeremyaaron's Avatar
Default 550 motors
over heating motor and blown esc = upgrade time
does anyone have any experience / recommendations with any of these motors:
-LRP X12L
-Tekin Redline SC4X
-Novak Ballistic 550 "Short Course"
-EPIC Monster Horsepower 550 "PRO-4"
all are advertised as the best, ultimate, but are similar in spec...
i run an epic monster 8.5t in by b4.1 and have had an exceptionally good run from it, but for the same price doesn't appear at face value to have the same tech that the others do... interested to hear everyones thoughts...
mrjeremyaaron is offline
Old 07-03-2011 | 06:14 PM
  #4080
bajabro's Avatar
I run the tekin rx8 with the tekin 4.5. The only thing i have done is ditched the radio tray due to the fact if you use that mount you will need to get an extension line for your servo to reach the receiver. There are only a few servos that come with a long enough wire to reach. I have run about 8 packs through my truck so far. I have crashed pretty hard a few times and nothing has broken yet.
bajabro is offline
