Like Tree5Likes
SC10 4x4 Thread
Old 07-03-2011 | 09:07 PM
  #4096
BlueGlowBoy's Avatar
Originally Posted by Dias
Need some advice on how to get the ballstud pushed through linkages.
Its feels as if I would break the linkage if I tried to force it on to the ball stud.
I was able to get the ballstud over the servo horn stud, but it took alot of pressure (bearing down very hard pushing down on it resting on a table)
Any tips/tricks to this?
Thanks in advance for any help.
I used some slip-joint pliers for mine... They let you push on the ballstud a little more evenly than using a pair of pliers that have a statick hinge (like needlenose pliers) plus they have a large flat surface to make things easy, and the longer handles give you more leverage.
BlueGlowBoy is offline
Old 07-03-2011 | 09:14 PM
  #4097
racer1812's Avatar
Super Moderator
Along with what's in the post above this one, the manual shows which side the balls need to be installed from. They definitely install from one side and not the other.
racer1812 is offline
Old 07-03-2011 | 09:21 PM
  #4098
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Originally Posted by Chad Smith
Yea the 1415 motor is awesome! I am running a 19 tooth pinion and i want to go bigger but room is the promblem. If you dont mind telling me, where did you sand the chassis to accommodate for the big motor can?
You can go bigger by using smaller spurs for the RC10GT2.
You can get them in 52, 54, and 56t flavors if ThunderbirdJunkie recalls correctly.
He will consult the packages his spurs came in and correct this post accordingly.
T-BirdJunkie is offline
Old 07-03-2011 | 09:32 PM
  #4099
BLbound's Avatar
I raced at west coast today. I used Cavs set up & the truck was a night & day difference with the front & rear sway bars! I qualified 3rd overall but blew it in the main & finished 5th. I'm looking forward to putting more & more battery packs through the truck!
BLbound is offline
Old 07-03-2011 | 09:33 PM
  #4100
bajabro's Avatar
Originally Posted by ilanstylz
What gearing are you running on yours at coyote's? I have a mmp with tekin 5.5 so was just curious...... I plan on running a 12/62 to see how that goes............
Running 11/62. Need to get a 12 tooth pinion for it.
bajabro is offline
Old 07-03-2011 | 10:51 PM
  #4101
ilanstylz's Avatar
Hey TBJ I was wondering, I am running a mmp w/ tekin 5.5 sc4x motor, I only have a 16t pinion for now, what size spur should I go with? Or is 16t just to much? Thanks
ilanstylz is offline
Old 07-03-2011 | 10:54 PM
  #4102
Honestly dunno...15 or 16 should be alright. Aren't most guys running 4.5s running 13s and 14s?
BTW...did you see the top secret stuff over at NC?
Old 07-03-2011 | 10:57 PM
  #4103
ilanstylz's Avatar
Well I just thought 16t was to much and would cause overheating, I ran it with the 16t/62p last week at the indoor track and after about 4-5 laps it was tempted around 160 I believe, so I'm thinking maybe if I drop the spur down to say a 56 I should be fine...... Oh and I'll check out NC after this
Old 07-03-2011 | 11:02 PM
  #4104
BLbound's Avatar
I'm running 12/62 with a 4.5 at west coast...I would think a 13 or 14 would be good for a 5.5 if your running at ocrc or wcrc.
BLbound is offline
Old 07-03-2011 | 11:03 PM
  #4105
ilanstylz's Avatar
Nah I run at Coyote Hobbies in Victorville....... I'm going to try dropping down to a smaller spur to see what happens. I did buy a 12t pinion but it hasn't came in yet........
Old 07-03-2011 | 11:04 PM
  #4106
It depends on the motor. If it's a short, small track (like the one you linked a video to on NC) a 15 is probably too big.
If you're not looking to gear higher (IE bigger pinion) then the bigger spur gears aren't in your cards...but they do allow more finite gear ratio adjustment.
Old 07-03-2011 | 11:06 PM
  #4107
big chris's Avatar
I am very satisfied with mine. I bought it Tuesday, had it completely assembled on Thursday. I ran two packs through it Friday to shake it loose then went to the local club race Saturday. Qualified 3rd with fastest lap and finished 4th, good for me! With a little more consistency I am in the top 3! Very happy, our track is a big 1/8 style track but the 4x4s run hard and fast on it. Props to the Castle 1410 and MMP, hung in there nicely with all the big 550 cans.
big chris is offline
Old 07-03-2011 | 11:44 PM
  #4108
BLbound's Avatar
Going to a smaller spur gear is like going to a bigger pinion...it will make the truck faster. I don't know how big coyote is, just watch your temps.
BLbound is offline
Old 07-03-2011 | 11:58 PM
  #4109
mrjeremyaaron's Avatar
Has anyone had any experience running this truck with the new Tekin, LRP or Novak 4.5T 550 motors that have been developed for this class..?
Just wanting to hear your feedback before i make a decision on which one to go with...
mrjeremyaaron is offline
Old 07-04-2011 | 03:32 AM
  #4110
racene1's Avatar
12t with my LRP 550L 4.5turn.
I am getting around 145 here in Vegas. (BTW, its 107 here now) 108 on the Rx8 speedo.
JT
racene1 is offline
