Team Associated RC8Be Thread >
Old 06-20-2011 | 08:45 PM
  #6421
Vegatron75's Avatar
Hey Guys, I'm looking to break out my converted rc8 this weekend. I'm looking for a good general set-up.
thanks.
Vegatron75 is offline
Old 06-20-2011 | 08:53 PM
  #6422
ferrarieeeee's Avatar
Originally Posted by Radarmy088
If. Do the diffs I want 5/7/3.....3 being the rear which is lighter fluid and more power? Am I correct?higher is heavier?
Yes
ferrarieeeee is offline
Old 06-21-2011 | 09:24 AM
  #6423
Default street tires
does anyone know what are good street tires for my rc8be. I will be running it on the street.
thanks
citizen16 is offline
Old 06-21-2011 | 12:15 PM
  #6424
just an fyi I am not sure if anyone is looking but i have a +3 chassis that is new. if someone is looking, dont need to sell it but if someone is in need let me know
Team T2C is offline
Old 06-21-2011 | 06:51 PM
  #6425
millerdui's Avatar
Default AE inventory week
About right. Stores can't keep upgrade parts in stock an AE shuts down for inventory. If it is there ship it out. If it's not there....get more in!!!
millerdui is offline
Old 06-21-2011 | 06:59 PM
  #6426
Originally Posted by Deaner
Put together the 8be kit this weekend, was my first kit car and I think I almost enjoyed putting it together more than driving.
I was going to order the rest of the parts I need, but I have a question about the RX8's, do they fit well with the stock motor mount or is the grid mount the way to go? Would it pay to mount the speedo on a bit of foam?
For the rest of my build I was planning on going with
2050kv combo w/hotwire
XP 1015 servo
AE 3chn fm27 receiver
DE mud guards
front and rear spring kits
bunch of different weight shock and diff fluids
assorted pinions and spurs
Anything else I may need or that you guys would recommend? I've been reading through the thread but there is so much info its hard to remember it all. For gearing I was going to try the stock 44/15 ratio on a tighter track... Does that seem a little low? Two other tracks I will run at are faster, more wide open tracks... what would you guys recommend for a 2050kv setup as a baseline for gearing?
Thanks!
Hands down this is the best material to mount your ESC with:
http://www.amainhobbies.com/product_...ng-Gel-1-Sheet
1day is offline
Old 06-21-2011 | 07:48 PM
  #6427
buggy8's Avatar
because of the thickness and adhesiveness?
buggy8 is offline
Old 06-22-2011 | 01:22 PM
  #6428
Anyone have a link to where I can buy different springs for the big bores? Most preferably from eBay. All I see are the 16mm ones are those the big bores or not?
These are what I found
http://cgi.ebay.com/Associated-89295...#ht_1446wt_689
Radarmy088 is offline
Old 06-22-2011 | 01:36 PM
  #6429
those are them, depending where in SoCal you are, you can find them for the same price as what Ebay guys sell them for.
1017racing is offline
Old 06-22-2011 | 01:58 PM
  #6430
Hay guys, Coming back to the R/C car world, been flying planes and helis for a
while and got a rc8be for fathers day...
I'm building it now and when I filled the diffs I filled them all the way up..Is that wrong, the manual didn't say...I did sand the face of the diff as I read on here though..
Weird, I made a post already and it didn't show for me so I made another one...
Turbotech is offline
Old 06-22-2011 | 02:17 PM
  #6431
Because of the way this gel material buffers those rough landings and soaks up any vibrations. It also sticks like mad.
1day is offline
Old 06-22-2011 | 03:01 PM
  #6432
From the top off my head i think the diffs are to be filled so that the bevel gears are covered with fluid. But i have been wrong before
Lars in Norway is offline
Old 06-22-2011 | 03:02 PM
  #6433
JEFFs SC10's Avatar
Ok guys looks like I'll be buying a used rc8be FT in great cond, it's a roller.
xp1015 servo work ?
ESC- mamba max?
Motor-Open to suggestions. looks like 17-1900 kv is the way to go.
Not sure if I should run it on 3s or 4s.
suggestions are GREATLY appreciated!!!
JEFFs SC10 is offline
Old 06-22-2011 | 03:26 PM
  #6434
Dlewis4's Avatar
xp1015 servo work ?
ESC- mamba max?
1015 will be fine.
Mamba max... or Mamba monster?
1900 is a great all around
4S.
Dlewis4 is offline
Old 06-22-2011 | 03:30 PM
  #6435
JEFFs SC10's Avatar
Mamba monster,
My shop has a Tekin/RX8 deal if that's a better system.
Thank you!
Hobbypartz batteries work good?
