Like Tree5Likes
SC10 4x4 Thread
Old 06-14-2011 | 10:54 AM
  #3196
Maybell's Avatar
Originally Posted by ffpm46
Does anyone know why AE site doesn't list the Rear Sway Bar anymore?
I see there is a pic of the from Bars.
The 91124 rear swaybar set is listed on the site, just no pic yet. Look under FT Parts and Accessories.
Maybell is offline
Old 06-14-2011 | 11:05 AM
  #3197
OSherman's Avatar
Default Did a lil tinkering..
The one thing i love most about this hobby..
i think it came out pretty swell.. Lets see how it/they perform on the track..
OSherman is offline
Old 06-14-2011 | 11:21 AM
  #3198
so whos using a 540 and how do u like it so far? my 550 melted down the other day and im gonna switch over to a 540...just wanna get a feel...by the way, my 550 died dut to an unexplained binding after a crash...i removed all the drive train expecting to find something broken, but nothing..put it all back and its free again...i dunno...
hondafixer is offline
Old 06-14-2011 | 12:14 PM
  #3199
1fastslash's Avatar
i guess a guy could have made some money if he was to sell hand made swaybars for this truck . I still cant get a set fro AE . very frustrating !!
1fastslash is offline
Old 06-14-2011 | 12:15 PM
  #3200
Cameron Kellogg's Avatar
I like the 540 motor in mine. I have posted this before but at the recent Northwest SC Nationals 1st and 2nd place ran 540 motors. (me being second ). We both were running 5.5 motors. I dont feel under powered at all. I actually had to dial my end piont back to keep the front tires on the ground.
Cameron Kellogg is offline
Old 06-14-2011 | 12:19 PM
  #3201
yea i remember ur post...did u put a fan on it? and if u did, did u do it just because or were the temps coming up? i ordered an lrp 5.5 so ill see how it goes
Old 06-14-2011 | 12:23 PM
  #3202
racene1's Avatar
Same thing happened to me, (the binding) I think what it is is the front of the belt, you know around the clicker, is either twisting or hopping up on the outer rail and binding up on the plastic cover. How often is the belt supposed to be changed?
THanks, JT
racene1 is offline
Old 06-14-2011 | 12:34 PM
  #3203
I built the truck with a fan installed. I needed weight on the electronics side to off-set battery weight so why not add a fan. Just from comments on here I thought it would be a good idea to have one on the motor. I was a little worried about speed control and motor temps but they are not really an issue with a fan. I run 10 min practice heats without issue. Granted I am not running full out crazy for that time but my set-up is working for me.
Old 06-14-2011 | 12:38 PM
  #3204
THanks, JT
Just like a real car. The last time before you drove it and it broke.
Old 06-14-2011 | 12:48 PM
  #3205
Cain's Avatar
I'd buy a set.
Cain is offline
Old 06-14-2011 | 02:06 PM
  #3206
1Fastpede's Avatar
Anyone solved the leaky diff syndrome yet?
if anyone wants a set of sway bars pm me for info, I'm selling mine.
1Fastpede is offline
Old 06-14-2011 | 03:06 PM
  #3207
JEFFs SC10's Avatar
can you grab a pic of your fan setup? any vids of you racing? good job racing!
JEFFs SC10 is offline
Old 06-14-2011 | 03:09 PM
  #3208
Maybell's Avatar
If you use green slime on the gasket and dont over/under tighten the screws, there should be no issue.
Maybell is offline
Old 06-14-2011 | 03:24 PM
  #3209
Originally Posted by Cain
what is your full setup on the ESC including software version?
What servo are you running and radio gear as well?
Not sure on the software version, it is updated as of May 15th so probably the latest version? Pretty much stock settings except for the timing is set to 30*, no punch control, no throttle profile changes, no drag brake, reverse is turned off, 50% brake power (probably should be turned up a bit) Im running the Airtronics MX3X radio, 92744 rx, and XP ds1015 servo. Temps after a 8min main on a high bite track with 16/62 gearing were 130 on the motor and 135 on the esc.
Keeferton is offline
Old 06-14-2011 | 03:28 PM
  #3210
1Fastpede's Avatar
i do use green slime and the gasket doesn't leak.. its leaking via the out-drives.
