SC10 Thread
Old 06-09-2011 | 10:13 AM
  #6106
Originally Posted by offtraxx
first chech to make sure all ur ball studs are tight. they can come loose and definatly affect the stearing. other than that, the plastic does wear out over time. u could have eggshaped the hingpin holes
all the ball cups are good I checked those and the hingpin was eggshaped thanks for that to look out for, although the servo I was using turns really fast to the left and noticeably slower to the right all the end points are the same on the radio. I used the Hitec ultra torque HS-645MG, I bought it used from a guy at the track for 30$ just to get rid of the stock servo I have used it for about a month with no problems now this. Oh and its slow to the right with a load on it and without a load on it.
losiracer753 is offline
Old 06-09-2011 | 10:47 AM
  #6107
Asharus's Avatar
Originally Posted by planede4mer
Quick question for all of you, is it common to wear out the right rear outer hub bearing faster than the rest on these sc10’s?
Using a standard roll pin axle or a hex conversion?
Asharus is offline
Old 06-09-2011 | 03:20 PM
  #6108
I have the factory team truck. with the standard roll pin.
planede4mer is offline
Old 06-09-2011 | 08:49 PM
  #6109
Asharus's Avatar
Ok just wondering. I've read that some people have been blowing out their rear outer hub bearings and thought it may be related to the hex conversions. I've noticed on my hex conversion kit (JC), the hex may squeeze into the bearing with more force when the wheel nut is tightened, compared to the stock roll pin setup. Maybe not though.
Asharus is offline
Old 06-10-2011 | 12:21 AM
  #6110
Eli's Avatar
Eli
Hmm two threads for the sc10 4x4... Ive read some people are running 6.5-7.5 540 motors. Im planning on doing the same with a tc spec v2 and not sure what 6.5 yet. Any sugestions from the guys running these?
Eli is offline
Old 06-10-2011 | 01:17 AM
  #6111
racer1812's Avatar
Super Moderator
this is the 2wd Sc10 thread........
racer1812 is offline
Old 06-10-2011 | 01:28 AM
  #6112
Eli's Avatar
Eli
whooopsie sorry bout that
Eli is offline
Old 06-10-2011 | 11:40 AM
  #6113
DirtRacer68's Avatar
Default Upgrading SC10 Performance?
Ok, as my signature indicates I have been racing an Associated FT SC10. I am considering using the 12mm front/rear wheel adapters from Proline. My questions are, does this improve performance and if so, how? I have alot of tire selection now using the axle pin wheels and this would be a downgrade because I wouldn't be able to use them. Is this a good move and if so, does anyone have any suggestions about the currently mounted tire stock? Should I remount them onto 12mm wheels or sell and rebuy my selection?
DirtRacer68 is offline
Old 06-10-2011 | 11:52 AM
  #6114
Matt Howard's Avatar
It doesn't really improve performance, just lets you use rims from your sc10 4x4 or other similar offset 12mm hex wheels.
Matt Howard is offline
Old 06-10-2011 | 12:37 PM
  #6115
Registered User
If you have a good selection of front tires currently, I would wait (that's what I am doing) and move to hex axles when you need new fronts. This may allow you to wait until the Associated hex front axles come out for the SC10 RS and see how they compare to the ProLine, AKA, and all the others out there. I would not suggest trying to pull already glued tires from your current wheels if you want to use them again
Ryno B4.1 is offline
Old 06-10-2011 | 12:44 PM
  #6116
Asharus's Avatar
I have the JC adapters and JC rulux 12mm wheels in the rear. I had no choice because the outdoor track I went to didn't have the SC10 wheels in stock on a race day for a set of goosebumps. At my other track (indoor clay) I use the SC10 wheels / barcodes.
Swapping out the adapter with the factory spacer is very easy and the adapter set is under 10 bucks. You'll still be able to use your factory wheels until you're done w/ the tires and eventually go full hex if you wanted to.
Asharus is offline
Old 06-10-2011 | 01:00 PM
  #6117
Tekin redline 8.5 paired with a MMP for racing mod sct on a big 1/8 scale outdoor dirt track and a smaller tighter outdoor dirt track be ok? Don't know if I should get a lower turn motor or higher or if 8.5 is good enough to be competitive.
machwon is offline
Old 06-10-2011 | 02:01 PM
  #6118
Numburn's Avatar
I have the Proline kit and am very disappointed with it. There is play between the axle and the bearings. There is also play between the pin and steering knuckle. That makes the front end very sloppy and is almost pointless to try to set camber properly. I called Proline about this. They told me to reuse the stock bearings and if it still has issues to take photos and email it to them. Changing the bearings did nothing so I took a small video showing all the slop and emailed it with a description to support. I then tried to call back and an automated message said they were closed, even though it was during their support hours. I tried calling back throughout the day to no avail. Now it's been a week with no reply to my message. I've switched back to the stock setup and will wait on Associated to release the hexes.
Numburn is offline
Old 06-10-2011 | 02:51 PM
  #6119
hmm, I've got my front hex conversion coming in the mail, hope mine isn't sloppy as well. I'll report back after I install it.
Old 06-10-2011 | 04:48 PM
  #6120
I appreciate everyone's responses about the 12mm wheel adapters. I think I will stick with my setup. I have several tire choices and am using GT front axles with rear axle spacers. This allows me to run a wider stance without needing sway bars.
