Team Associated RC8Be Thread >
Old 06-06-2011 | 03:41 AM
  #6271
witchblade's Avatar
Default grid mount
maybe i should call team grid and cancel my order then
witchblade is offline
Old 06-06-2011 | 03:53 AM
  #6272
Hahaha.... That would be a straight up mistake.
Hey, everyone is entitled to their opinions regarding the mounts. I certainly respect them to the utmost. I would just ask yourself this when making your consideration if you should, or should not get the grid mount:
Does anyone who gave you advice it's not necessary to run with a grid actually own a grid?
Sure... It makes the motor more secure than the stock one, but it also allows for quick pinion and motor changes in comparison to the stock mount.
A friend told me long ago when it comes to advice you get on rc tech: "take it with a grain of salt".
Just do the research then you decide
Sarinexia is offline
Old 06-06-2011 | 04:10 AM
  #6273
Originally Posted by subaru_tech
after 5 min run.with a 12 pinion on now.
esc=80,motor=95,batts=90.
next 2 minutes after first temp check,total power loss.
battery (neg) lead came off the deans connector.
im hoping the cold solder joint was causing high resistance.
You are way under geared! You should use a 18 or 19T pinion.
bohdi is offline
Old 06-06-2011 | 04:53 AM
  #6274
kaiser's Avatar
after 5 minutes geared 19/46 with the 1900kv i was @ 163.
i geared down to 17/46 and after 8 minutes i was at 150.
not too mention 19/46 seemed way too fast on our track.
kaiser is offline
Old 06-06-2011 | 05:31 AM
  #6275
DoogieLee's Avatar
Thats entirely up to you, in your original post, you stated that you were waiting on the Grid mount to arrive, and that you didnt want to run the car without it.
I took that as you thinking the stock mount wasnt up to par at all, the point I was trying to make is that it is.
I dont have any personal experience with the Grid mount, I have inquired about it, but my personal experience with the stock mount is that it hasnt failed me, and i've put it through some serious abuse.
Thats the only point I was trying to make...
I dont want anyone from Grid getting pissed off at me thinking I swayed a potential customer, that was not my intention at all.
DoogieLee is offline
Old 06-06-2011 | 05:33 AM
  #6276
Ed237's Avatar
Originally Posted by DavidR
Hey guys...What all do I need to order to convert to the current worlds spec (Old RC8) steering rack?
The main items are:
Rack 89235
Turnbuckles 89072
Ballstuds (4) 89075
Ballends (4) 89074
You may or may not need different size mounting screws for clearance
Ed237 is offline
Old 06-06-2011 | 05:40 AM
  #6277
Ed237's Avatar
I have run the stock mount for over a year in all sorts of conditions and I have never had an issue with gear mesh. I'm still running the same motor. I have never missed a qualifier or race because it took me too long to change the pinion.
The stock mount is more than adequate.
The real question is whether or not the Grid mount is worth $70.
Ed237 is offline
Old 06-06-2011 | 06:59 AM
  #6278
kaiser's Avatar
AE'S out of stock on the 89121 diff oring set. everyone else seems to only have the old style (all black) in stock.
anyone know where i can get a set with the clear ones?
kaiser is offline
Old 06-06-2011 | 07:07 AM
  #6279
A while back (around Jan / Feb) time frame there was a lot of conversation in this thread regarding how to stop leaking. Of course the sanding method is well known, but these O-Rings were also recommended for being a little more heavy duty. Many have stated after the sanding and installation of these rings they have had zero issues:
http://www.amainhobbies.com/product_...asket-For-Diff
part # [MUGC0257]
Old 06-06-2011 | 07:12 AM
  #6280
kaiser's Avatar
i have a set of those one the way. i figured while i was in there i'd upgrade to the clear ae orings.
kaiser is offline
Old 06-06-2011 | 07:20 AM
  #6281
Driving style is a big reason I am sure
Every person should start at the correct gearing and go from there but 12 is way under geared.
bohdi is offline
Old 06-06-2011 | 07:41 AM
  #6282
kaiser's Avatar
lol, you're right. it was "hammer fest" right out of the gate.
new track surface too, really loose.
kaiser is offline
Old 06-06-2011 | 10:55 AM
  #6283
DavidR's Avatar
Originally Posted by Ed237
The main items are:
Rack 89235
Turnbuckles 89072
Ballstuds (4) 89075
Ballends (4) 89074
Thanks!
I really appreciate it! Saved me a bunch of time!
-David
DavidR is offline
Old 06-06-2011 | 11:05 AM
  #6284
per4m28's Avatar
Those temps are good I read about the same on the 19t depending on o/s temp maybe a bit lower.
per4m28 is offline
Old 06-06-2011 | 11:17 AM
  #6285
per4m28's Avatar
Stock mount is definitely more than capable...grid and elite is just an extra and for some maybe worth the convenience.
per4m28 is offline
