SC10 4x4 Thread
#391
#393
I had a Slash 4x4 w/Ballistic 550 4.5. I ran a 13 pinion but it got hot. I jumped to a 16 and temps went down. The 13 was reaching max rpm too often causing it to get warm. Just a thought.
#396
The 60k diff fluid would effect steering like tightening a ball diff would. Thicker fluid would be the same as tightening your diff down.
If you run a front overdrive or rear under drive that will allow the front wheels to pull you out of corners, would benefit most on loose tracks.
The Clicker helps by allowing you to turn into corners better by allowing the front wheels to free spin while you are hitting the brakes allowing the back tires to lock a little and slide you around tight corners similar to how a 2 wheel drive vehicle would turn a corner.
For example, what combination (if any) would you suggest for running on a medium/loose/loamy track with 1/8th scale jumps?
Chris/anybody?
#397
I found that when leaving the belt tensioners on the uppermost setting (shown on some AE setup sheets), the belt is a little too close for comfort to the sides of the belt cover and could rub.
I don't understand why belt tension is considered a "setup" Seems like there should only be one correct tension and should not have much effect on car otherwise except a bit more friction to the front end.
Can someone elaborate on why there are different belt tension settings shown on the setup sheets?
#398
I believe the binding is the flats on the sides of the gears crashing into the teeth of the opposing gear. I suspect that a slight bevel/chamfer on that side of the opposing gear teeth would prevent it from snagging the flats.
I considered sanding them a bit to do just that... but then I figured just running it will clearance it better.
#399
#400
I know its sensorless, but it does have a sensor port on it. I ask because the motor gets very different degrees of timing depending on how its plugged into the vxl and could be why he's running so hot.
#402
I didn't know that. Learn something new every day. Is that the AUX port? Never popped it open to be honest.
Heck, I'll be bolting a Novak 550 4.5t in my boy's Slash 4x4 tonight then, heh.
#403
The upper shock bushings are way too sloppy though. Also I noticed the springs, like every other coil spring, aren't perfectly straight and they can rub slightly on the shock body. This will only get worse as the piston and ID of the shock wear.
2. I am not sure if my 5 mm nut driver shrunk, but I had to use a 7/32 nut driver to tighten all of the 5 mm nuts. (try to figure that one out)
#404
I know this truck don't need a Carbon Fiber parts but my ears are open for any ideas or suggestion guys.
Steve Nguyen
www.snrgraphite.com
Steve Nguyen
www.snrgraphite.com
#405
5Likes
