Like Tree5Likes
SC10 4x4 Thread
Old 05-11-2011 | 09:54 AM
  #376
Wild Cherry's Avatar
Same body as the 2W Sc-10, not sure how thick , but its a durable shell ...
Kits tires look good for bashing on asphalt & base ball diamonds ...
Wild Cherry is offline
Old 05-11-2011 | 10:06 AM
  #377
Originally Posted by DRFTPRO
Hey guys I hope the building is going better for you than me. I built mine in about 6.5 hours. I am using a tekin 5.5 sc4x. I matched it with a 14t instead of a 13t pinion that the manual called for. my motor is getting a little hot and that is after 4 minutes running. What bother me most it that when i flat out accelerate the motor acts like it has a rev limiter on it and it wont go fast at all. When i accelerate smoothly it will hit a normal top speed. Iam using the VXL ESC out of a slash 4x4. If any one can give me some insight I would appreciate it.
Maybe not enough tension on the belt and it is slipping when you punch it. Just a thought. I don't know what kind of power the VXL puts out but perhaps you are pulling to much when you punch it with the Tekin 4.5
Keep'N It Cool is offline
Old 05-11-2011 | 10:09 AM
  #378
BlueGlowBoy's Avatar
Only got the servo installed on mine last night before the wife cut the power to my workshop so I had to go to bed...
Savox 1267MG - Servo wire is way too short. Needs an extension.
Also, the stress relief rubber on the side of the servo (where the wire comes out) binds a bit on the servo mount.
I was thinking of trimming it...
BlueGlowBoy is offline
Old 05-11-2011 | 10:23 AM
  #379
Tension seems good but I will check it. Do you recommend the 13t pinion cuz I was under the impression that going up in the teeth would keep the engine cooler. Thanks a bunch bro!
DRFTPRO is offline
Old 05-11-2011 | 10:27 AM
  #380
DirtDrop's Avatar
Going up in the pinion makes it run faster putting more stress on it. Id say try the 13
DirtDrop is offline
Old 05-11-2011 | 10:30 AM
  #381
jks's Avatar
jks
Is anybody going to use a Speed Passion Esc/motor combo? Always wondered about quality and performance.
jks is offline
Old 05-11-2011 | 10:36 AM
  #382
Cain's Avatar
How does the compound feel compared to the SC10 2wd stuff? Had heard it was a better compound.
Cain is offline
Old 05-11-2011 | 10:39 AM
  #383
CentralCoaster's Avatar
Originally Posted by 1Fastpede
wow did anyone else struggle with finding bolts? i ended up 4 M3x14 bolts missing. and one shock had leaked everything into bag. and no diff fluid in diffs.
That's funny because I think my kit had 4 extras. Were they buttonheads?
CentralCoaster is offline
Old 05-11-2011 | 10:40 AM
  #384
TocSin's Avatar
I didn't notice a difference in the tire compound.
TocSin is offline
  #385
Cult Racing's Avatar
Originally Posted by SaladFork
Damn Cult you have been busy lol, now I know wth you have been.
hahaha ya I have! been double checking everything and makin sure everything is good, I still havent driven it
Cult Racing is offline
Old 05-11-2011 | 10:41 AM
  #386
TocSin's Avatar
Me, too. Not sure where those guys go
TocSin is offline
  #387
Originally Posted by T-BirdJunkie
They look to be the same inserts that are used in the std SC10 kits. They're pretty firm.
Stock tires and foams are HEAVY!
Also the outer edge of the foam is notched out a bunch for the thick stock tire webbing... i would not recommend using it with other types of tires... or else the outer edge of your tire will have very little foam support.
Old 05-11-2011 | 10:42 AM
  #388
Cain's Avatar
Thanks for the info. Hmm, I'll mount them anyway, not bad having a set of tires for the kids to try out on or some carpet duty.
Cain is offline
Old 05-11-2011 | 10:44 AM
  #389
Default savox and RX8
does anyone needed a servo extension cord or Savox servos?
And anyone already managed to fit a tekin rx8 any mods needed
Caju is offline
  #390
Originally Posted by Bburns
As long as it isn't binding, rolls pretty smoothly and the belt tension is set right. You should be good to go.
I found that when leaving the belt tensioners on the uppermost setting (shown on some AE setup sheets), the belt is a little too close for comfort to the sides of the belt cover and could rub.
I don't understand why belt tension is considered a "setup" Seems like there should only be one correct tension and should not have much effect on car otherwise except a bit more friction to the front end.
Can someone elaborate on why there are different belt tension settings shown on the setup sheets?
