EB Mods JS Engine
Old 03-22-2011 | 01:31 PM
  #1741
Brian Miskolczi's Avatar
Ed Please give me a call 240 298 4020. Been trying to get ahold of you. Thanks.
Brian Miskolczi is offline
Old 03-24-2011 | 06:20 AM
  #1742
EBMods's Avatar
Brian just called and left you message call me back.
EBMods is offline
Old 03-24-2011 | 06:35 AM
  #1743
EBMods's Avatar
Originally Posted by RX313BT
Hey guys have just finished breaking in my JS23R, i have pulled the head off just to have a look at things and noticed that there was two aluminium shims but no brass shims! is this normal? I have a JS21 as well, which had one aluminium and two brass shims, and we removed one of the brass shims which realy helped with tune and performance and was going to try the same with the 23R, any info would be greatly appreciated.
Cheers
Scott
Hello Scott,
Stock JS .23 has three aluminum shims. Two 0.2mm and One 0.3mm. Here in the US we run the two 0.2mm shims. Total 0.4mm in shims
Stock JS .21 - In the US we remove the aluminum shim and only run the two cooper shims. Both these shims equal the one aluminum, which is 0.3mm
EBMods is offline
Old 03-24-2011 | 06:38 AM
  #1744
EBMods's Avatar
Originally Posted by 1quickvic
Hey Ed, When are the Hellfire Race Prep engines going to ready for order...Thanks!
Um, they should be on AMain and Absolute web sites. If not just give me a call to place an order.
1-800-678-1037
EBMods is offline
Old 03-26-2011 | 05:27 PM
  #1745
RX313BT's Avatar
Originally Posted by EBMods
Hello Scott,
Hi Ed and thanks for the response, i have just double checked my 23 and it had One 0.5mm shim and One 0.2mm shim, both aluminium, i double and tripple checked and there were not a 0.2 and a 0.3 stuck together? but i did remove the 0.2 shim on the weekend leaving only the 0.5mm and i did help a lot with tune and performance, but i have modified two OS 0.1mm shims so i can try 0.4mm in shims.
Cheers
Scott
RX313BT is offline
Old 03-26-2011 | 06:00 PM
  #1746
rceefreak's Avatar
IS the 086 pipe still the best pipe for the 23? HAs anyone tried the 2041 pipe on the 23?
rceefreak is offline
Old 03-26-2011 | 07:03 PM
  #1747
Hello Scott,
Hi Ed, I have just looked at my stock .21 and it has three copper and one aluminum shims. I have not changed them since having the engine. I purchased it here in New Zealand which might explain why. One of the copper shims is thicker then the other two copper shims but not as thick as the aluminum one.
I run 30% nitro, what do you suggest I take out.
Regards,
Gerard.
bopracer is offline
Old 03-28-2011 | 04:19 AM
  #1748
RX313BT's Avatar
Regards,
Gerard.
Hi Gerard, yes definatley remove the shims that Ed has suggested, we had lots of tuning issues with our 21s untill we removed shims, and they also perform a lot better as well, and we also run 30% nitro, give it a try the thicker copper shim should be 0.2mm and the thinner should be 0.1mm, not sure about the ally one, but i would say you could just use the copper ones as they should shim to 0.3mm.
Cheers
Scott
RX313BT is offline
Old 03-28-2011 | 04:23 AM
  #1749
RX313BT's Avatar
Hey guys also i need a EFRA pipe to run on my JS23R, as i dont think the 086 is EFRA approved, i have a HongNor 2047 EFRA pipe which is a top end pipe and a OS 2060, would one of these work ok? or are there any other suggestions?
Cheers
Scott
RX313BT is offline
Old 03-28-2011 | 08:53 AM
  #1750
Officespace's Avatar
Stock JS .21 - In the US we remove the aluminum shim and only run the two cooper shims. Both these shims equal the one aluminum, which is 0.3mm[/QUOTE]
Does the "race ready" JS .21 still come with the aluminum shim and the two copper shims? I just wanted to check with everyone before I pulled the head off my relatively new "race ready" JS engine to remove the aluminum shim as Ed suggested.
Officespace is offline
Old 03-28-2011 | 11:28 AM
  #1751
Cheers
Scott
Yes, I have done this and will see how it goes.
Cheers.
bopracer is offline
Old 03-28-2011 | 12:17 PM
  #1752
STUBYSLAP31's Avatar
I just thought id post up some new pictures of my brand new AGAMA A8. I jumped to AGAMA/JS after being a AE or nothing guy for a couple of years. So far I am incredibly impressed with the both the AGAMA and JS.
STUBYSLAP31 is offline
Old 03-28-2011 | 02:12 PM
  #1753
Nice! How do you like the Agama? I'm good friends with Gene Hickerson, the US distributor of Agama and VP Pro and he's asked a few times for me to switch over from my Losi's to the A8 buggy and their soon to be released truggy.
I've driven the A8 buggy a number of times and my impression is that it is a VERY touchy and unforgiving buggy to drive. I'm a decent driver, but it seems like this buggy was set up to be driven only by top professional drivers and any little mistake you may make, it makes you pay - in a hard way. It might be just the actual buggies I've driven (they were all Agama factory driver's cars, including Gene's, and he can still hang with some of the best in the world on the racetrack), so I'd actually like to get an opinion on the buggy from someone outside our little Florida circle.
Old 03-28-2011 | 02:40 PM
  #1754
pm ed
Old 03-30-2011 | 10:06 AM
  #1755
EBMods's Avatar
All the engines that come from me, are shimmed and ready to go for 30% Nitro.
EBMods is offline
