Go Back  R/C Tech Forums > International Forums > Australian Racing > XRAY Australia
1:8TH GP Offroad Setups & Discussions >
Rate Thread
Old 03-06-2011 | 05:05 PM
  #61
hyper9boy's Avatar
kc shore
pre nats set up
http://forum.teamxray.com/xform/inde...91&setup=xb808
hyper9boy is offline
Old 03-07-2011 | 04:56 AM
  #62
blade954's Avatar
Ari
Noticed you have a 14t clutch bell down for the 808 Prenats is that correct.... How was the track by the video looks to break up...
blade954 is offline
Old 03-07-2011 | 01:45 PM
  #63
OLD 69's Avatar
Company Representative
Originally Posted by blade954
Ari
Yes i had 14/46 Spur & 12/40 Diff Ratio to try and smooth out the acceleration... the track was pretty rough.
...Ari
OLD 69 is offline
Old 03-07-2011 | 03:27 PM
  #64
hyper9boy's Avatar
huuuum
ari
what would u say the most difference is when running
front and back arms all the forward,
as oposed to all the way back
ta
Old 03-07-2011 | 04:15 PM
  #65
OLD 69's Avatar
Originally Posted by hyper9boy
huuuum
ari
ta
Its all about weight position & transfer. Arms forward will transfer more weight to the rear of the car, less steering low speed as there is not as much weight on the front end, but the car will slide out more in the rear due to weight shifting in the corners.... it will act a lot like a drift car in a sense. I personally dont like that setting too much.
I ran my front arms forward for better jumping and the rear arms in the middle, its quite neutral but the main reason is it jumps & lands better this way.
...Ari
OLD 69 is offline
Old 03-23-2011 | 05:13 AM
  #66
blade954's Avatar
Well must say we ran the new 808 @ the Nationals just gone and what a rock solid performer the new chassis is super smooth drive chain and that's the way it stayed all weekend I must say its a great feeling knowing the bearings are up to the job and after pulling the car apart yesterday the bearings are as good as the day they went in. The new car with its new changes are up on the 10 spec that's for sure, Big thank you to the rest of the xray team for a great weekend every one made us welcome and made for a great weekend of racing even if the weather gave us grief. Look forward to some of the gents heading over to the W.A state titles.... O' and i was a bit skeptical on the new shell but after seeing one painted up they are a great complement to the new car....
Big thanks to HEI for the support @ the Nationals as well jaicob really loved the atmosphere and racing (and the shirt Ari)...
Jason & Jaicob
blade954 is offline
Old 03-23-2011 | 06:41 PM
  #67
juzza99's Avatar
cant wait to get over there to race, the new car is another step up,for sure.
juzza99 is offline
Old 03-27-2011 | 06:22 AM
  #68
pantera nitro's Avatar
What shock springs, pistons and oils were you boys running at the Nats and which sway bars?
Thats if it works the same for the 808-2010 but if not can you give me your recommendations on what I should use please?
Clampy.
pantera nitro is offline
Old 03-27-2011 | 06:34 AM
  #69
blade954's Avatar
We run 1.1x10 hole pistons front and rear with 37.5wt up front and 32.5 in the rear with blue greys worked well 2.4mm sway bar up front and 2.6mm on the rear... The other gents had different set ups with piston and oil but the end result was very close....
Here is a vid of the above set up..
http://www.youtube.com/watch?v=-MCXhDBjefY
As you can see the 808 seamed settled and jumped nice...
blade954 is offline
Old 03-27-2011 | 06:26 PM
  #70
juzza99's Avatar
Clampy.
I was running 1.2mm 8 hole front 550w xray oil, 1.1mm 10 hole rear 500w xray oil with dark blue springs, I think ari and mick zlotowski were using same piston setup but heavier oils and blue gray springs.
Sway bar front 2.4mm rear 2.8mm, but i dont think the track will be the same as it was a couple of weeks ago.
The stock setup is quite easy to drive,just change the shocks to what you think.
juzza99 is offline
Old 04-18-2011 | 04:38 AM
  #71
blade954's Avatar
Well the Western Australia state titles were run over the weekend and Team Xray had quiet a good show with Justin Snape KC Shore Brent Thomas and Jaicob Mann all running Buggy and Jaicob running Truggy as well. Weather was great all weekend and Sunday the Dark clouds did roll in and just sprinkle enough to turn the track into a perfect track for finals. All drivers driving great all weekend and Xray had a good showing in the Buggy final with Juzza KC and Jaicob getting in the Amain. The 2011 spec 808 is one hell of a chassis now it is a fantastic platform right out the box now...
Here is the buggy finalists
And Jaicob in Truggy
Truggy was super quick all weekend just bad luck had us down in the Final with the right rear roll center screw coming loose and forcing us out Qualified 4 over all... Buggy we had a good run finishing 7th at the end 808 was great right through the main.....
will get some set ups and more pics up soon...
was good to have some more drivers over hear to talk set up and get the buggy fined tuned even more thanks Juzza & KC Jake enjoyed you guys being there.... See you gents at ACT.....
blade954 is offline
Old 04-18-2011 | 04:05 PM
  #72
blade954's Avatar
blade954 is offline
Old 04-18-2011 | 05:40 PM
  #73
juzza99's Avatar
Sure was a fun race, Had a blast..
Track surface and grip was the best ive ever driven on.
Thanks heaps for all your help over the weekend jason, much appreciated.
juzza99 is offline
Old 05-24-2011 | 08:35 PM
  #74
OLD 69's Avatar
Ari Bakla 2011 808
2011 NSW States
Maitland
http://forum.teamxray.com/xform/inde...tup=xb808_2011
OLD 69 is offline
Old 05-24-2011 | 08:42 PM
  #75
OLD 69's Avatar
Ari Bakla XT8
2011 NSW States
http://forum.teamxray.com/xform/inde...=443&setup=xt8
OLD 69 is offline
