Pro Trak
Old 07-14-2019 | 03:32 AM
  #526
Originally Posted by kiyano
Setting in the calibration table 42 to 1 can increase the charge current to 15A. But for this you need to check the following
1. The lifetime of the charge FET will be shorter than at 12A
2. The 20A version of PRO-TRAK has poor heat sink cooling capability. So you may need external fan cooling
3. When PRO-TRAK is shipped, it is adjusted for 12A charge current. Even if Software allows charging current up to 15A, the current may not actually increase up to 15A. In that case, it is necessary to readjust PRO-TRAK
Hi I have the 30 amp version with the big heat sink.
It looks like i will have to buy a changer that can do 25 amps for stock racing....
Smoking motor.. is offline
Old 08-29-2019 | 09:06 AM
  #527
Hi I am looking for details on how to make the serial coms cable for this charger, also the pc monitoring software for a version 10.83
is this information still available anywhere??
I know its old tech by I'm a ex-vintage racer that still like to fiddle with these vintage things!
Many Thanks
h1973uk is offline
Old 08-29-2019 | 09:22 AM
  #528
V12's Avatar
V12
Still have my Protrak somewhere in storage.
Someone remembers when this awesome charger have been introduced?
I think in the 1990's but not sure when.
V12 is offline
Old 08-29-2019 | 09:29 AM
  #529
I bought my original one around 2002/2003 not sure how long they had been around for
h1973uk is offline
Old 01-09-2024 | 06:37 AM
  #530
Default Pro Trak v12.20 ICS
Well. This is a heck of a thread revival. Nearly 20 years since the topic I am interested in was discussed on here! Thanks for staying open RcTech!
im looking for a late model ICS board that plugs into the BMS instead of having to use standalone ICS board and monitor cables.
thought it was worth a post here to see if anyone could help… the Pro Trak is still a great charger.
im actually in UK, home of the pro trak, but the company is long since closed
i have a unit which was repaired and upgraded in 2009 at pro trak, and runs v12.20
I have an invoice for the repair and upgrade cost, a few bits of original literature etc, a pretty cool piece of history
an even better piece of equipment for diagnosing and improving NIMH packs!
hope to get some replies
thanks
Mr Noisy is offline
