Team Associated RC8Be Thread >
Old 03-20-2011 | 12:08 PM
  #4531
well forgot to thread lock the set screw on the pinion so i just ran 15t for about 5 minutes and it did seem a little slow. might go up to like an 18.
smagistro is offline
Old 03-20-2011 | 12:12 PM
  #4532
GreggW's Avatar
18 is a very good start.
GreggW is offline
Old 03-20-2011 | 12:18 PM
  #4533
jmackani's Avatar
Default First weekend out report
I had both of my sons out this weekend for there first practice runs on the rc8be's they got for christmas. Box stock setup with the holeshot tires. Tekin 1900 systems. Car looked pretty decent. Only thing I noticed after trying it was the on corner exit push under power. So, we will make some changes to try and correct that. Nothing broke on either of the cars. Cars were both very stable and both boys did well with them. Only problems were the screws in the front aluminum hubs. The one car they kept backing out. So we ordered more screws and I plan on locktiting the crap out of them and then using some shoe goo to keep the screw tacked to the a-arm. Very little wear on the tires also. This is a 100% top soil sifted track so it's very tame on tires.
jmackani is offline
Old 03-20-2011 | 12:21 PM
  #4534
Car looks sick, now box it up and fly down to FL so i can whoop you on the track =P
agarabaghi is offline
Old 03-20-2011 | 01:08 PM
  #4535
per4m28's Avatar
Turnigy in general is a decent battery, Ive had Turnigy that lasted me a few years and some that just went bad. Good bang for the buck!
Originally Posted by Vegatron75
I'll be joining the ranks of the 1/8th scalers soon! Waiting on my kit to show up.
Any use this lipo? The BE tray dimensions are 143x53 from what I've read. Looks like this one will fit?
RATED: PRODUCT ID: T5000.4S.30
Turnigy 5000mAh 4S 30C Lipo Pack (USA Warehouse)
The new number one in performance and price!
The new Turnigy Lipoly packs deliver full capacity at the said C rate.
You wont find a better deal in Lithium Polymer batteries anywhere!
Spec.
Minimum Capacity: 5000mAh
Configuration: 4S1P / 14.8v / 4Cell
Constant Discharge: 30C
Peak Discharge (10sec): 40C
Pack Weight: 537g
Pack Size: 143 x 49 x 32mm
Charge Plug: JST-XH
Discharge plug: 5.5mm Bullet-connector
per4m28 is offline
Old 03-20-2011 | 02:30 PM
  #4536
Arigato's Avatar
Default CVD's
Originally Posted by jwmustang
I bent one after 6mos, I straightend it, still using it. What does wear are diff housing 89115 & 89113. I thought it was the bearings but it wasnt. I dont know why they dont have bearings there. Its just a bushing. It will make the diff outdrive wobble.
How do you straighten them out?
Arigato is offline
Old 03-20-2011 | 02:44 PM
  #4537
chris c's Avatar
I use a vise to straighten mine
chris c is offline
Old 03-20-2011 | 04:21 PM
  #4538
Divey's Avatar
Got my build done today. Body still needs painting but other than that it's all ready to go. Handles like it's on rails. I have to get used to it compared to my truggies. Setup:
MMP/1800kv 1512
Tekno V3 kit
775 for the diffs
45wt front shock fluid
40wt rear shock fluid
Prolien Caliber
geared 18/46
HPI SF-32TT servo (same as the hitech 7955tg)
Runs good but a little slow on 4 cell lipo. Speed calculator estimates it at 37mph. On 5s it runs good with good speed. The motor would run more efficient of 5s but I wanted to run 4s because of the weight. Would it be better to gear up to a 20t pinion or keep it the same. It will be mostly ran on 4s unless I run out of all those then 5s.
Also what color scheme should I do for the body. Those are some Parma decals on there.
Thanks for looking,
Terry
Also one more thing, the front DE skid plate, does it mount the square end towards the front or rear?
Divey is offline
Old 03-20-2011 | 04:25 PM
  #4539
buggy8's Avatar
+1
I also place it on a non-rebounding surface *wood* and tap it with a hammer. It's hard/near impossible to get the perfect after being bent
buggy8 is offline
Old 03-20-2011 | 04:27 PM
  #4540
buggy8's Avatar
MMP/1800kv 1512
Tekno V3 kit
775 for the diffs
Prolien Caliber
geared 18/46
Thanks for looking,
Terry
nice! thanks for sharing
I have the same v3 kit. what size pinion are you running?
They are coming out with a 19t pretty soon that I'm waiting for.
buggy8 is offline
Old 03-20-2011 | 06:04 PM
  #4541
that front motor mount looks sweet
I would like to wheel one set up like that
monsterbrad is offline
Old 03-20-2011 | 06:22 PM
  #4542
20t seems a little high for a 2200.
I have the 2200 system and on the advice of others on this thread, I geared up to a 20t pinion and wow what a difference! The buggy came to life! The motor temp after 6 mins was 158 degrees. Perfect!
Todd-ORCCC is offline
Old 03-20-2011 | 06:52 PM
  #4543
my 1900 is geared 20 it runs great
  #4544
schnellschnell's Avatar
MMP/1800kv 1512
Tekno V3 kit
775 for the diffs
Prolien Caliber
geared 18/46
Thanks for looking,
Terry
Nice setup. Where did you get those dust covers for the center CVAs?
The front skid plate? Only mounts one way as I recall. The rear is square end to the back.
jason
schnellschnell is offline
Old 03-20-2011 | 08:00 PM
  #4545
buggy8's Avatar
Default Ball Diff??
this may be a dumb question but is there a ball diff for this?
would a ball diff be better than a gear?
buggy8 is offline
