Team Associated RC8Be Thread
#4517
#4518
does anybody know which blue lipo fits the tray
looking for 4s
wanted the gen ace but they are all out and the battery from timbuckttooo
will not be here any time soon also
should have looked into shipping a bit before ordering
oh well it will get here eventually
if you guys could post some other battery options for us guys looking that would be cool
looking for 4s
#4519
looking for 4s
looking for 4s
#4520
here is my rc8 just need my silver rear springs to get here gunna swap those with the stock ones and than i will be ready to go.
setup: MMM esc, Neu 2200, Jr 9000t, 4s lipo
current gering is 15/46 not tested yet.
775 diffs 30 wt front 25 wt rear.
#4521
Looking good. Pinion is way small. That's the standard one. I would run a 20 tooth.
#4525
It seems weird i know, but trust me, thats what you will need to run with this car. anything less and you will be severely undergeared.
#4526
I've talked to the guys at Tekin about gearing and I have a 2050 geared at 20/45 and a 1700kv geared at 22/45. temps are spot on. I would gear your motor at 19/45
#4528
#4529
I'll be joining the ranks of the 1/8th scalers soon! Waiting on my kit to show up.
Any use this lipo? The BE tray dimensions are 143x53 from what I've read. Looks like this one will fit?
RATED: PRODUCT ID: T5000.4S.30
Turnigy 5000mAh 4S 30C Lipo Pack (USA Warehouse)
The new number one in performance and price!
The new Turnigy Lipoly packs deliver full capacity at the said C rate.
You wont find a better deal in Lithium Polymer batteries anywhere!
Spec.
Minimum Capacity: 5000mAh
Configuration: 4S1P / 14.8v / 4Cell
Constant Discharge: 30C
Peak Discharge (10sec): 40C
Pack Weight: 537g
Pack Size: 143 x 49 x 32mm
Charge Plug: JST-XH
Discharge plug: 5.5mm Bullet-connector
Spec.
Pack Weight: 537g
Charge Plug: JST-XH
#4530
Spec.
Pack Weight: 537g
Charge Plug: JST-XH
Spec.
Pack Weight: 537g
Charge Plug: JST-XH
