Team Associated RC8Be Thread
#3766
Just called the hobby shop to get a second opinion. He pretty much agreed with me, the "c" rating is for the "punch" off the line. When your using a 2250Kv truggy motor in a buggy your really not too concerned about the "punch" because your going to smoke the tires no matter what "c" rating you use. Does everyone else agree with this? If so I am going to order those 20c rated batteries.
#3768
#3769
You must have a pretty good charger. Mine will only charge 5amps. What charger you using? Is this off topic? In my opinion it's BS for us to have to go to a new forum for a few people that don't know how to use a serch this thread button..... Not saying no names but yeah!
#3772
#3773
boo lhs.
Went there and all they had was 13ga. Once again impatient and picked it up. Its running fine, but i would prefer 12guage...
the 2050kv still impresses me.
I didnt start the timer when i got out there, but we ran for a while before my pinion came loose. I forgot to put lock tite on it
Came back out and started the timer. We basically we did non stop drag races and on road speed run in a rather large parking lot. The losi is running a 2100kv Losi 8th scale setup (esc). Gearing is at 15t pinion, stock spur. The car is running Road Rage buggy tires, and will wheelie on command
The rc8be is a Tekin T8 2050kv geared at 20t / 46t.
Batteries were slightly different. The Rc8be ran a hardcase turnigy 30/40c 4500mAh. The losi 8ight was running turnigy 4s 25/35c 5000mAh. The rc8be pretty much had the losi on every run, though some where close.
Overall im very pleased with the T8 motor, not sure if there is any extra performance over the castle / neu motors, and if so that it is worth the price difference.
Any, pretty stoked, and hopefully i can get to the track soon.
... Came back out and started the timer. We basically we did non stop drag races and on road speed run in a rather large parking lot. The losi is running a 2100kv Losi 8th scale setup (esc). Gearing is at 15t pinion, stock spur. The car is running Road Rage buggy tires, and will wheelie on command
#3776
Here you go:
Details of V2 Chassis:
3mm longer than OEM chassis
Lighter than the OEM Chassis
All un-used holes filled for better wear, no more plastic inserts
Developed for and tested by Team Associated Factory Team Drivers
Hey guys, just to let you know, Bill will have the new RC8BE V2 chassis available for purchase tuesday on the website, they will be in stock ready to ship. I will also have a small stack of them with me for nitro challenge, if you are headed there and would like to reserve one. Please PM Me.
#3778
Ha! I just noticed that. I was thinking about buying one, but my chassis is perfectly fine; not to mention that I'm not nearly as good of a driver to be able to tell the difference.
BTW, I just received the Dialed Inc Buggy Bag. Very nice. I like it, although I didn't count on my antenna tube being too long. Gregg, did you coil up your antenna in the receiver box and use a really short antenna?
#3779
